306 axle
306 axle
Question iv a 306 dturbo needing a new axle back is drums if i buy a 306 axle with disks and pads can i put my drums straight on ??
You can fit a beam with discs you just need the hand brake cables for a disc beam
So everything else fits 100 precent ? I dont need to buy anything except hand brake cables ?
As long as the beam is complete wih discs, pads, calipers, shocks and axle mounts. All the axles bolt on the same way with the 6 16mm nuts under the boot carpet
Will also need disk handbrake cables
I have a complete lowered beam just needs hand break cables
Team Doesn't own a 306
Im from nothern ireland so maybe dear to post ??
Probably costs £40 mainland uk
How much would u want including postage
Dont forget about ABS Smile
[Image: 65613_10200761612710317_1548698655_n_zps68c27004.jpg]
CONVOI EXCEPTIONNEL
