306 axle - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: 306 axle (/showthread.php?tid=23198) |
306 axle - pbell283 - 13-04-2014 Question iv a 306 dturbo needing a new axle back is drums if i buy a 306 axle with disks and pads can i put my drums straight on ?? RE: 306 axle - Frosty - 13-04-2014 You can fit a beam with discs you just need the hand brake cables for a disc beam 306 axle - pbell283 - 13-04-2014 So everything else fits 100 precent ? I dont need to buy anything except hand brake cables ? RE: 306 axle - Frosty - 13-04-2014 As long as the beam is complete wih discs, pads, calipers, shocks and axle mounts. All the axles bolt on the same way with the 6 16mm nuts under the boot carpet RE: 306 axle - Danny2009 - 13-04-2014 Will also need disk handbrake cables I have a complete lowered beam just needs hand break cables 306 axle - pbell283 - 13-04-2014 Im from nothern ireland so maybe dear to post ?? RE: 306 axle - Danny2009 - 13-04-2014 Probably costs £40 mainland uk 306 axle - pbell283 - 13-04-2014 How much would u want including postage RE: 306 axle - martyn92 - 13-04-2014 Dont forget about ABS
