adjusting the wastegate
Is there a set amount of turns to shorten the wastegate for 22 psi or are they all trial and error
Seem to remember this being trial and error... mine went quite a bit on this but not as much on my old hdi strangley
(09-04-2014, 09:10 AM)tuttyboy84 Wrote: Is there a set amount of turns to shorten the wastegate for 22 psi or are they all trial and error
Can't you just buy a Adjustable Boost Controller ?
Think it's a bit easier to fit then adjusting the Waste gate
If fitting a boost controller then you still have tonadjut thw wastegate, but you over adjust it and then use the controller to bring it back down.
Id rather just set the wastegate then not worry about it again and im pretty sure if fitting a boost controller you only interrupt the the pipe from turbine to wastegate rather than moving the wastegate arm
Mine was a good couple of turns IIRC and there wasn't much thread on the bar, it boosts around 19psi
Ok thanks and what does iirc mean???
if i remember correctly
Surely. 22 psi is a bit much
It's about the limit of a stock turbo, anything more than that and it'll pop pretty quickly
Anything above 19 is a bit daft imo, if you look at the compressor map for these turbos it clearly shows the efficiency dropping horribly at about 21psi. And that's without thinking about flow limits or exhaust back pressure, there's no need for it.
Mines setup on just an mbc and is perfect, no boost spike or anything
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
  Wastegate actuator DeeTurbo 1 2,412 17-11-2016, 06:55 PM
Last Post: Poodle
  how to adjust the wastegate.... Arron 12 7,259 29-09-2012, 07:50 PM
Last Post: Chris_90
