01-03-2012, 08:51 PM
just bought a 02 Hdi estate and the clutch is biting about 10mm off the floor, not sure if the clutch is new or on its way out, or if i should just change the cable? its the first Hdi iv owned
Clutch bite point
01-03-2012, 09:13 PM
A low bite is better than a high one.
01-03-2012, 09:16 PM
Just had my clutch changed, Mine was literally on the floor before it was biting. Not sure if just changing the cable will help .. Are they not auto adjusting ?
On the 306 waiting list.
01-03-2012, 09:43 PM
just gave it a test, it would rather stall than slip, its like the self adjuster has not reset after a new clutch, is it possible to manually push the ratchet back in?
01-03-2012, 10:07 PM
I heard that stamping on the pedal can sometimes sort the adjuster :/ i wouldnt try it til its been confirmed though haha
02-03-2012, 08:10 AM
Also heard that if you spray a bit of wd40 onto the cable it will work it's way up to the ratchet it helps with the problem. Again not confirmed but something to look into.
02-03-2012, 08:13 AM
should fit a new cable with a new clutch
a few hard stamps on the pedal might help but I doubt it will in this instance!
02-03-2012, 11:51 AM
Few hard stamps will make it tighter! If you push it down then let go of the pedal so it springs back a few times, that'll loosen up the cable and then it'll auto adjust once you start driving
02-03-2012, 12:54 PM
Toms306 Wrote:A low bite is better than a high one. Thats good news mine comes up 1/4 so there must be loads left.
| Clutch biting point | shervo | 2 | 2,811 |
19-03-2015, 08:34 AM Last Post: shervo |
Crank gear setting point | Mr_Nuclear | 9 | 7,497 |
29-12-2014, 08:30 AM Last Post: Mr_Nuclear |
