Belt Area Squeal - PAS Pump?
#31
£30 on ECP with discount anyway lol.
And, nope, mine gets louder with revs, it's bloody annoying at motorway speeds!
#32
Is it leaking on the belt causing slip mone was!
#33
As above, if the belt is tight and squealing isn't cured by revs then there's another issue. The tensioners can take up quite a lot of slack between them, could probably just about use a 1190 tbh.
(10-04-2014, 05:31 PM)pugmanxud Wrote: Is it leaking on the belt causing slip mone was!
Wasn't leaking, but replaced now anyway...squeal disappeared for a short while before coming back.
(10-04-2014, 06:38 PM)Poodle Wrote: As above, if the belt is tight and squealing isn't cured by revs then there's another issue. The tensioners can take up quite a lot of slack between them, could probably just about use a 1190 tbh.
Ah I didn't realise that, thought the belt tolerances were a little smaller tbh. Ordered one now anyway, 1183. Smile
  Cost of Timing Belt and Water Pump Replacement? JTaylor2005 7 6,213 12-02-2018, 03:29 PM
Last Post: JTaylor2005
  Best timing belt kit and water pump? JTaylor2005 13 8,251 23-09-2016, 10:11 AM
Last Post: BiG K
  Squeal when turning wheel DTubZz 5 3,398 24-04-2014, 07:31 AM
Last Post: DTubZz
