Threads: 18
Car Model/Spec: 306 Dturbo s 1998
im running a lucas pump and garret t2 turbo I was wondering what would be the mos I can get out of the turbo I was planning on fitting a front mount also does anyone no how much it would cost for one plus piping and im running around 18 psi at the min I was going to try for 25 or around that ??
Threads: 203
Car Model/Spec: Peugeot 306
would spend the money on a decent bosch setup than a front mount if it was me
+1 to the bosch.
People have seen fine figures without FMIC at stg1 with std turbo
Threads: 18
Whats a bosh setup just a pump ? Also is it hard to change from lucas to bosh pump also what kind of money
Threads: 203
get a bosch setup for about £80/100 u will need pump lines and injectors all u need to do to fit it is swap the pins over on ur mounting bracket to the next holes up and just a 12v live to top off stop soliniod jobs done
Threads: 18
Cool ok what could i get the turbo boosting too without it blowing ? Also once i do over 110 my car seems to overheat alot ?
Threads: 18
Not speeding do some drag racing not on public roads
