Urgent: dturbo intercooler
I've just gone to plumb up my boost gauge and snipped this pipe to put the t piece on[Image: de7e6u3y.jpg]
And some oil came out
I've seen on some forums that a little bit is
normal in older diesels but mine seems to be boosting ok not down on power so could it be the turbo seals on the way out
NO SMOKE NO POKEBig Grin
normal tbh.
(15-07-2013, 06:02 PM)padge Wrote: normal tbh.
Thank god for that. Ha. I've been wanting to do a turbo change for a while to a bigger one but haven't experienced any loss in power so could be on its way out.
Could I still fit my boost gauge or will oil go into it. It comes supplied with a filter for the vacuum line
Or could it just be build up. Took the pipe off completely and there was hardly anything so could be build up. It is a 15 year old diesel tbf
That'll be probably a bit of oil from the breather system - they breathe their crankcase vapour to the inlet system, so it'll always be a bit oily... Your turbo may well be passing a bit of oil too, but I've seen turbos last for another 100k when just passing a little oil, it's not uncommon at all...
My turbo has been doing it for the last 20k miles, nothing to worry about unless you get a chronic whining sound from it!!!
Yer as said normal tbh, best to put a small filter in your boost gauge pipe just in case.
(15-07-2013, 06:10 PM)Ruan Wrote: That'll be probably a bit of oil from the breather system - they breathe their crankcase vapour to the inlet system, so it'll always be a bit oily... Your turbo may well be passing a bit of oil too, but I've seen turbos last for another 100k when just passing a little oil, it's not uncommon at all...
(15-07-2013, 06:11 PM)Chris_90 Wrote: Yer as said normal tbh, best to put a small filter in your boost gauge pipe just in case.
Thanks. It came with a filter so ill definitely put it on.
  306 dturbo & intercooler pbell283 7 4,033 08-04-2014, 08:50 AM
Last Post: pbell283
