Which clutch...?
Which clutch...?
So which clutch would people use for a stage 2 HDi?
It's been converted to an XUD clutch.
I want it to be good for at least 200BHP and 330lb/ft.
Cheers Smile
CG solid center 4 paddle and uprated pressure plate.
£200.
Mates got that in his car and its fine, tad judery but getting better as its wearing in. Same as what JP has too.
[Image: sig.jpg]
why the solid centre? Isn't the sprung centre smoother and generally better?
Sprung center is nicer to drive but your car will snap the springs in the center plate (trust me ive done it)
IMO id go for a helix paddle.
Dont trust CG anymore.
As chris said with s2 power up you'll snap the springs in them.
And the unsprung ones arnt as bad as you think they would be.
[Image: sig.jpg]
Cheers.
Dum, will a helix GTi6 clutch be the correct one or do I need an HDi one?
If you have the dt setup you'll need the gti one, unless they do a speciffic dt one. Or to run the hdi one you'll have to swap everything back to standard.
[Image: sig.jpg]
thought so. cheers.
