29-03-2014, 05:34 PM
Just get drill out and bodge them on
-40mm drop...perfect
![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg)
New Daily - Fiat Punto Grande 1.9 MJet - Added Pictures
![]() -40mm drop...perfect ![]() ![]() the smokey old bus that sounds like a tractor...
29-03-2014, 06:18 PM
Sell your clones to meee !!
01-04-2014, 11:32 AM
02-04-2014, 09:42 PM
(This post was last modified: 02-04-2014, 09:45 PM by SupaStar88.)
Fiat [SMIRKING FACE]
Fix It Again Tomorrow [FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY] But no serious best fiat I ever had was [DISAPPOINTED BUT RELIEVED FACE] erm.... Probably my mk1 punto running 423hp from the coupe 20v turbo [FACE WITH TEARS OF JOY] till I twisted the car and had to. Scrap it cause it was down as a 1.0 [TIRED FACE]
Using Tapatalk
04-04-2014, 09:28 AM
Anyone have an idea what size wheel these take.?
04-04-2014, 02:20 PM
04-04-2014, 02:39 PM
(04-04-2014, 02:20 PM)Poodle Wrote: http://www.carlsalter.com/wheel_fitments.html Contradicts other websites values, so not helpful I'm afraid. ![]()
04-04-2014, 08:20 PM
04-04-2014, 10:14 PM
Same as my old rims Trent, I want them on MYA
05-04-2014, 02:04 PM
I bought them this morning, they fit, center bore is smaller in punto so needs one of those spacer things.
Also found out it has locking wheel nuts that I don't have they key for, luckily Toyotas box if locking wheel nuts had the right one in! Also treating them to a set of new 195/55/15s. ![]()
12-04-2014, 09:37 AM
Need a set of spigot rings to convert from Fiat fitment (56.1) to whatever these are as the bolts will eventually work themselves loose.
Also need a new wheel more than likely as it hum's like a bad man... ![]() Probably wouldn't hurt to get the poundland black spray paint on the go for a touch up of the alloys either.. Full valet, paint correction, polish & wax and new set of tyres all round: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Did an oil filter & oil change last night. What a ball ache! The oil fitler is enclosed in a casing above the drivers side driveshaft behind the back of the engine!
Also, my OBD2 blue tooth adapters arrived so I'll be looking at getting the app to work on the Nexus later. I need to reset the maintenance spanner warning now somehow. Also fitted my spigot rings to help hold the wheels on.
30-04-2014, 08:09 AM
Whenever I see this thing I think of:
30-04-2014, 08:18 AM
30-04-2014, 11:18 AM
These don't map too badly tbf, EDC16 IIRC and they're from the same stable as the GM CDTi motors so there's lots of options out there.
(30-04-2014, 11:18 AM)Ruan Wrote: These don't map too badly tbf, EDC16 IIRC and they're from the same stable as the GM CDTi motors so there's lots of options out there. Feel free to elaborate Ruan. ![]() It has a GT1749MV, good for 210 bhp? FMIC as standard. Engine code: M737 PUNTO 130CV / (Z19DT? / 1.9TiD?). Everyone on FiatForum uses RedDot. Surely TB/JammaPic/ProSteve/MrWhippy could have a pop at it. ![]() Wiki info on engine: http://en.wikipedia.org/wiki/JTD_engine Info: The Multijet second generation features a common-rail design and is available with seven different power outputs. The 8-valve version has 100 PS (74 kW; 99 hp), 120 PS (88 kW; 120 hp) or 130 PS (96 kW; 130 hp), the last four with variable geometry turbocharger; and the 16-valve version have 134 PS (100 kW; 136HP), 138 PS (103 kW; 140HP), 150 PS (110 kW; 150 hp) or 170 PS (130 kW; 170 hp). Opel also uses a version of this engine. Their CDTI engine, manufactured in Pratola Serra, Italy and Kaiserslautern, Germany, is the product of the half-decade joint venture between GM and Fiat. It is used in the Vectra, Signum, Astra, Zafira, Cadillac BLS and Suzuki SX4 as well as some Saabs marked as TiD and TTiD (twinturbo version). Applications: Alfa Romeo 145 Alfa Romeo 146 Alfa Romeo 147 Alfa Romeo 156 Alfa Romeo 159 Alfa Romeo GT Cadillac BLS DR5 Fiat Bravo Fiat Brava Fiat Croma II Fiat Doblò Fiat Grande Punto Fiat Marea Fiat Multipla Fiat Punto Fiat Sedici Fiat Stilo Fiat Strada Lancia Delta Lancia Lybra Lancia Musa Opel Astra H - 2004-2009 "1.9 CDTI engines with 120 and 150 PS" Opel Signum Opel Vectra C - 2004-2008 "The four-cylinder diesel engine was replaced in 2004 by a Fiat-designed 1.9 litre Ecotec CDTI engine capable of producing 89 kW (119 hp) in 8v form and 110 kW (148 hp) in 16v form." (Dulled down version of mine?) Opel Zafira B Saab 9-3 Saab 9-5 Suzuki SX4 Alenia Aeronautica Sky-Y
30-04-2014, 11:44 AM
(30-04-2014, 11:26 AM)silverzx Wrote:(30-04-2014, 11:18 AM)Ruan Wrote: These don't map too badly tbf, EDC16 IIRC and they're from the same stable as the GM CDTi motors so there's lots of options out there.Surely TB/JammaPic/ProSteve/MrWhippy could have a pop at it. I think Steve and JP have had a play with EDC16 in the past, they are a bit different since they're torque based ECUs rather than IQ based like EDC15, but there's a good bit of info out there on them tbf... Yeah, should be good for ~180-200hp at a guess... Yours is an 8v, right?
30-04-2014, 11:53 AM
(30-04-2014, 11:44 AM)Ruan Wrote:(30-04-2014, 11:26 AM)silverzx Wrote:(30-04-2014, 11:18 AM)Ruan Wrote: These don't map too badly tbf, EDC16 IIRC and they're from the same stable as the GM CDTi motors so there's lots of options out there.Surely TB/JammaPic/ProSteve/MrWhippy could have a pop at it. Yes, as far as I understand it's an 8v and the Punto's never came with the 16v.
25-07-2014, 03:16 PM
I saw this a while back, never had a whole lot to add... but thought I'd let you know I mapped one the other day and for what it was, it was el rapido. Really really good torque and pulled right through!!!
Can be read with the same MPPS / Galletto we use for the HDi's too!! :-) JP
JP
(25-07-2014, 03:16 PM)jammapic Wrote: I saw this a while back, never had a whole lot to add... but thought I'd let you know I mapped one the other day and for what it was, it was el rapido. Really really good torque and pulled right through!!! I'll PM you, wouldn't mind a map! ![]() New wheels: ![]() ![]() ![]() New wheel bearing: ![]() ![]()
21-11-2014, 03:38 PM
RPM's for my reference:
6th Gear: 100mph 3,000 90mph 2,700 85mph 2,550 80mph 2,400 70mph 2,250 60mph 1,800 50mph 1,500
21-11-2014, 04:33 PM
Are you still driving this turd wagon???
(21-11-2014, 04:33 PM)puglove Wrote: Are you still driving this turd wagon??? Yeah boi. It's making it's attendance in Exeter on Sunday for the meet and quite likely the Xmas meet depending on if I can be arsed to drive the Datsun with a welded all the way. Does 53MPG and is quicker then a 306 HDi 1+. ![]()
21-11-2014, 04:52 PM
Yes it maybe better in every way that a hdi except that it make colossal lady garden lol tbh i forgot you had this
(21-11-2014, 04:52 PM)puglove Wrote: Yes it maybe better in every way that a hdi except that it make colossal lady garden lol tbh i forgot you had this Hah, fair enough. I still dribble when I see ph3' 3 doors. ![]() Need to give my DTub a nice polish tomorrow and see how it looks all shined up. Should be bad ass enough! This is just a milage muncher really, does 1,000-2,000 miles a month. £15 11.7 83,511 19/11 BP £10 7.9 83,394 18/11 Esso £20 15.9 83,198 13/11 Tesco £40 31.8 82,826 08/11 Tesco Full £50 39.7 82,444 30/10 Tesco Full £30 32.5 82,186 26/10 Tesco £25 19.5 81,902 20/10 Tesco £10 7.7 81,886 20/10 BP £30 23.5 81,611 15/10 Tesco £10 7.6 81,547 14/10 BP £40 31 81,090 05/10 Tesco Full £53 39.6 80,752 28/09 Tesco Full £57 42.5 80,290 20/09 Tesco Full £35 26.1 79,960 13/09 Tesco £30 22.5 79,628 07/09 Tesco £30 22.6 79,386 01/09 Tesco £40 30.1 79,089 27/08 Tesco £10 7.4 79,033 16/08 BP £35 26.1 78,715 10/08 Tesco £30 22.4 78,471 05/08 Tesco £30 22.4 78,265 31/07 Tesco £15 11. 78,060 28/07 Tesco £25 18.4 77,958 25/07 Tesco £10 6.9. 77,908 25/07 Esso £25 18.4 77,603 19/07 Tesco £25 18.4 77,368 14/07 Tesco £35 25.7 77,145 09/07 Tesco £15 11. 77,083 09/07 Bp £15 11. 76,821 25/06 Tesco £40 29.5 76,646 22/06 Tesco £30 22.1 76,375 15/06 Tesco £40 28.4 75,997 08/06 Tesco £25 18.3 75,705 02/06 Tesco £25 18.3 76,506 28/05 Tesco £40 29.9 75,272 24/05 Tesco £50 36.5 74,889 17/05 Tesco £25 18.3 74,583 11/05 Tesco £35 25.8 74,314 03/05 Tesco Oil 10w40, filter, spigot rings 29/04 £40 30.2 74,007 27/04 Tesco £30 22.3 73,830 12/04 Asda
21-11-2014, 05:00 PM
Well tbh you need somthing pratical doing that sort of mileage . Atleast with somthing like this you wont be temped to play with it to much
21-11-2014, 05:07 PM
I quite like this for some reason
