28-02-2012, 01:41 PM
They are pretty bad boxes! Very weak!
![[Image: Foxy2.jpg]](http://i1224.photobucket.com/albums/ee369/Foxy-jim/Foxy2.jpg)
Info on a cam.
28-02-2012, 01:50 PM
IIRC When i was on Sax-P you can get a conversion kit and run a 6' box on the TU engines
28-02-2012, 02:37 PM
They're disposable gears, use once then throw away, make it lighter. You can run the BE box with a conversion plate but it gets pretty spendy as you need hubs, bearings, shafts, mounts, BE4R 'box and a load of other bits and pieces.
Might have a work with the bloke doing the gears for the buggy on a price for a new gearset tbh... Foxy - watch how much you skim off, it needs to be matched to the engine flow/cam specs (mine had a fair bit of chamber work to help it with high compression) and you'll need to advance the cam timing if you take off as much as I did.
28-02-2012, 05:32 PM
Foxy-jim Wrote:They are pretty bad boxes! Very weak! Yep.....my old 1.4 has had 4 of them now lol! ![]() |
