Wanted: 306 40mm Lowered Rear
Hey, after a 40mm lowered rear torsion jobbie.
Too lazy and un skilled to do the lowering part, changing it looks 10x Simpler, though, probably underestimated that as well.
If anyone has one ; give me a price to ponder,
Cheers!
I have a drum axle with abs lowered about 60-80
[Image: ForumSignature.jpg]
Oof, A tad too low IMO, If I go lower then 40 at the front I scrape like a bastard on my local roads (plus its my work 'van' ) , is the bar easier to adjust when its off the car?
And how much would you want for it ?
Took me and guys about 3hours to swap beams...took me about 45min to adjust the height!
Fancy giving me a hand for return plumbing related services? ^^
Lowering a rear beam isn't hard. It's only a bitch when they're seized, which most are now at this age.
(18-03-2014, 01:03 PM)Piggy Wrote: Took me and guys about 3hours to swap beams...took me about 45min to adjust the height!
Lots of tea breaks?
I swapped 2 beams over on my own Sunday, barely took any time at all. Ok so I ruined a brake line but without that would've been all done and back together in an hour and a half...
Drop the exhaust and spare wheel/cage. Remove brake cables, remove brake lines then its just 6 bolts in the boot....how does that take 3 hours? Confused
  Wanted: Disc Rear Beam, Lowered Preferably bigcheez2k3 3 2,781 22-09-2012, 10:13 PM
Last Post: the milkman
