Steels to alloys?
Managed to get a fairly cheap set of alloys. Just a few questions. Firstly will they fit? Is the tyre size ok? And I need to get the flat type bolts, is that correct.
The size is 195/50r15
[Image: aze2ebat.jpg]
Yes, they'll fit fine. They're standard Cyclones which came on the higher spec models. That tyre size is fine, factory is 195/55s but a lot of people change to 50s as they're cheaper. Yes, flat seated bolts for Cyclones.
Thanks.
Will these bolts be ok? http://www.ebay.co.uk/itm/Peugeot-206-10...4861785519
They are the correct bolts yeah, But I'll do you a set cheaper @ £20 posted.
Chris.
Cheers Chris. C2K is already sorting me out with a set. Cheers again.
[Image: meberazy.jpg]
Finally fitted my cyclones.
Much better...looks loverrly
