Will these fit?
Will these fit?
Hey,
Found a set of Speedline 2118's in 15x6 et30, would these fit directly to my GTi6?
Cheers
Drew
et30 sounds a bit much, pretty sure the off set for the 306 is 15 to 22 with a 65 bore
You'll need at least 5mm. I'd wack some hub centric 10mm spacers on
(13-03-2014, 11:23 AM)Matt Wrote: You'll need at least 5mm. I'd wack some hub centric 10mm spacers on
so they would fit with some 10mm spacers?
But would look better with 15mm hubcentric spacers
And longer bolts..
[Image: Cn91r40h.jpg]
