Will these fit? - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Will these fit? (/showthread.php?tid=22141)
Will these fit? - DrewHughes - 13-03-2014
Hey,
Found a set of Speedline 2118's in 15x6 et30, would these fit directly to my GTi6?
Cheers
Drew
RE: Will these fit? - underground375 - 13-03-2014
et30 sounds a bit much, pretty sure the off set for the 306 is 15 to 22 with a 65 bore
RE: Will these fit? - Matt - 13-03-2014
You'll need at least 5mm. I'd wack some hub centric 10mm spacers on
RE: Will these fit? - DrewHughes - 13-03-2014
(13-03-2014, 11:23 AM)Matt Wrote: You'll need at least 5mm. I'd wack some hub centric 10mm spacers on
so they would fit with some 10mm spacers?
RE: Will these fit? - puglove - 13-03-2014
But would look better with 15mm hubcentric spacers
RE: Will these fit? - 7057sam - 14-03-2014
And longer bolts..
