Will I need spacers?
Buying theses oem 307 xsi 17" alloys for my 306 estate and wanna know will I need spacers if so what size ??
yes you will and it's 10-15 mm iirc mate ...Smile
Got some 9.5m but need the bolts can anyone tell me what wheel bolts I need or a link to fit these with the 9.5m spacers?
I don't think the standard 307 tires will fit without rubbing. The tire size you need are 205/40/17.
I'm unsure of the spacer size, I've got to fit mine and I've got some 20mm spacers to try.
I've fitted them and are fine as they are just I don't have the longer bolts so need to order some but dunno how long the bolts I would need
36mm long is standard so you will need 45mm long bolts.
http://www.ebay.co.uk/itm/4-M12-x-1-25-4...1e78e6402c
You might want to send them a message asking if there the right length.
It is the flat type you need for them wheels.
