Will I need spacers? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Will I need spacers? (/showthread.php?tid=22087) |
Will I need spacers? - MIKE-FORD - 11-03-2014 Buying theses oem 307 xsi 17" alloys for my 306 estate and wanna know will I need spacers if so what size ?? RE: Will I need spacers? - Mattcheese31 - 11-03-2014 yes you will and it's 10-15 mm iirc mate ...
RE: Will I need spacers? - MIKE-FORD - 11-03-2014 Got some 9.5m but need the bolts can anyone tell me what wheel bolts I need or a link to fit these with the 9.5m spacers? RE: Will I need spacers? - DeeTurbo - 11-03-2014 I don't think the standard 307 tires will fit without rubbing. The tire size you need are 205/40/17. I'm unsure of the spacer size, I've got to fit mine and I've got some 20mm spacers to try. RE: Will I need spacers? - MIKE-FORD - 11-03-2014 I've fitted them and are fine as they are just I don't have the longer bolts so need to order some but dunno how long the bolts I would need RE: Will I need spacers? - DeeTurbo - 11-03-2014 36mm long is standard so you will need 45mm long bolts. http://www.ebay.co.uk/itm/4-M12-x-1-25-45mm-PEUGEOT-GENUINE-ALLOY-WHEEL-FLAT-SEAT-WASHER-LONG-SPACER-BOLTS-/130877374508?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET&fits=Car+Make%3APeugeot&hash=item1e78e6402c You might want to send them a message asking if there the right length. It is the flat type you need for them wheels. |
