81
(02-03-2014, 10:30 PM)Poodle Wrote: Yeah, because peugeot bodged a half-hydro setup into some engines because all the later engines used proper hydro clutches, no? As far as i was aware the only benefit to installing a hydro clutch was the increased torque-holding, which isn't exactly a worry on this, or is it? Basically i don't get why you've done it, why have you done it? ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
becauseracecar
Threads: 55
17
Car Model/Spec: 406 V6
There's no increased torque holding, it's just lighter pedal effort (less friction) and longer lasting/self adjusting.
Fair enough, mostly a comfort mod then? Not being picky just wondered why Grant had done it, it's not exactly like his usual racecar mods is it lol.
Threads: 169
91
03-03-2014, 06:55 AM
(This post was last modified: 03-03-2014, 07:15 AM by Grant.)
Half hydro setup? Im assuming you mean as this does not use a concentric slave cylinder on the input shaft of the 'box?
The same setup as has been used in the:
-Ford Transit
-Land Rover Freelander
-Lotus Esprit
-Mazda RX8
-Rover 45
-BMW Mini (exactly the same cylinder in fact)
The list goes on...
The only benefiting factor as to how much torque the system would hold would be how strong it is. i.e. a hydro setup would more easily depress a much heavier clutch. A concentric system, granted more so, but not a problem in this, or many applications.
As to why I have done it; whilst the original design is not 'shit', it leaves a lot to be desired. It is far from light, the auto adjustor leaves your pedal invariably at the top or bottom of the travel range, and mostly, when the adjustor gets hot it gets 'notchey'. So you have a 'on' or 'off' clutch. Mainly due to the fact that it sits directly under the exhaust manifold getting nice and toasty.
This setup should eliminate all of this.
And as Rowell says, becauseracecar
Fair enough, i'm with you, interesting cheers!
Threads: 169
91
This is all, of course, if it works
Threads: 226
24
Car Model/Spec: A3 TDi
Who cares what its for its fricken awesome, for no reason!
Threads: 186
38
Car Model/Spec: MG ZR VVC
Hydro clutch = racecar
Rover cars have hydro clutch
Rover = Racecar
Yes the logic is unquestionable
Interesting build though man impressed
Threads: 169
91
(03-03-2014, 07:07 PM)Tom Wrote: Who cares what its for its fricken awesome, for no reason!
It kind of is for no reason: When the new engine goes in, it will be completely redundant ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif) Ah well.
(03-03-2014, 08:35 PM)lolsteve Wrote: Hydro clutch = racecar
Rover = Racecar
Whatever helps you sleep at night mate
But cheers. It does for now.
Spent most of this afternoon and evening making my own gear stick, from the selector arm up. Pain in the arse, but done. Pics to follow when I CBA. Ive sat down with a beer now
Threads: 226
24
But no one else has one and you made that all yourself, its impressive man :p Not to mention its just different.
Threads: 169
91
Haha cheers dude.
Credit to him, me and Niall have spent many evenings scribbling away on beer mats in the pub, and flinging many links to different things back and forth.
There was one guy on the '6 forum who made a hydraulic setup, but he had his gearbox machined out to accept a concentric cylinder on the input shaft.
Sadly I don't own a CNC machine, or have a large abundance of money, so I will not be doing this
Threads: 51
Car Model/Spec: Did Have Track Prepared GTi 6
(01-03-2014, 06:43 PM)devils_fuel Wrote: Is that a formula 1 or 2 stock car as the vid isn't working for me ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png)
Spent many hours 10+ years ago going to stock car events with a mate as he had a formula 2, an uber tuned 2.0 ford lump and that was rapid on a short oval at Cheddar and Taunton
Thats a mate of mine in a F1, he was F2 world champion, Mick Sworder. Yes the F2s are just as good and in fact quicker over a lap. Who was you're mate?
Yet again grant, f*cking fair play! How do you even think this stuff up?
Hydro clutches are much nicer. Unfortunately the 306 design is a rather poor one. I don't know about other models but the gti, if you get it properly hot really gives a hot clutch due to the manifold being just that bit closer to the adjuster i think.
Good thing with the hydro set up is its much nicer to use and self adjusting. A concentric cylinder would be a neater install but as i found out with my old work car, if they leak or fail, its a box off and new clutch job which is just a pain in the arse. At least with the external slave set up, if it goes pop, its 10 mins to change and 10 mins to bleed.
Tbh, with the amount of people that moan about the 306 clutch, I'm surprised its not more widely done. We will find out on saturday for certain but on paper, its very very simple!
Threads: 96
7
Car Model/Spec: 306 tractor
03-03-2014, 11:01 PM
(This post was last modified: 03-03-2014, 11:02 PM by devils_fuel.)
(03-03-2014, 10:24 PM)Tallguy_2 Wrote: (01-03-2014, 06:43 PM)devils_fuel Wrote: Is that a formula 1 or 2 stock car as the vid isn't working for me ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png)
When I used to go racing Rob speak was world champion and bill batten was uk champion...longtime ago.
My mate was a cheddar boy, Paul Scorse but he raced all over the south west. I used to love watching the bangers in cheddar, the cheddar headers (i.e. The mk 1 Granada crew) in the demolition derby wtf
Awesome work there grant, you're a busy beaver
Why are you wasting all this time and money being a pussy and fitting a hydro clutch when it could be spent fitting a manly V8?!
Threads: 169
91
(03-03-2014, 11:40 PM)Piggy Wrote: Why are you wasting all this time and money being a pussy and fitting a hydro clutch when it could be spent fitting a manly V8?!
So far this setup has cost me £9.50. When completed I reckon it will be around £35 quid. It's something to do that hasn't been done before
Only teasing really grant...seems bargain too!
And you may need the hydro master at least for the v8 gearbox/clutch.
...guess I just wana see a v8 in a 306 more than a hydro clutch!
Threads: 169
91
(04-03-2014, 07:31 AM)Piggy Wrote: Only teasing really grant...seems bargain too!
It's cool dude. And yeah, you and me both. I'm gonna have to buy an engine soon so it's forces me to pull my finger out!
Threads: 169
91
So what do you do when you want to shorten the throw on your quick shift but eh original gearstick is too short?
Make your own!! Of course!
Then what do you do when you have lowered it so much it fowls the exhaust?
Move it to inside the car and space it to f*ck!
Thats a nice idea actually, raises it up to a more useful position.
Nicely done
Threads: 169
91
So, good productive day today:
Niall came over bright and early. We went to the scrappie, weighed in some shite we had lying around, and that has paid for our FCS tickets
Then got the hydraulic clutch fitted and working ![Rofl Rofl](https://www.306oc.co.uk/forum/images/smilies/legacy/Skype/rofl.gif) So nice and smooth and ever so light!
There were a couple of hiccups along the way but managed to get them ironed out. Its dark now so will get better pics tomorrow.
Hydraulic clutch in a 306? Awesome! How easy/cheap was it to do?
£7.50!!!!
A lot of fabrication work but overall it was easy if you have access to a grinder and welder
£7.50 sounds good... Fabrication with dangerous power tools not so much!
wow...cheap...I assume the £7.50 was for the oil/fluid flexi line?
This is also a good mod for when upgrading to a beefier clutch I guess
Threads: 90
Be interested to see what you did at the pedal end of the hydrolic setup chaps ? Good work....
Threads: 541
124
Awesome it works
Threads: 169
91
(08-03-2014, 09:25 PM)Piggy Wrote: wow...cheap...I assume the £7.50 was for the oil/fluid flexi line?
Truth be told, the entire setup has probably set me back about £35, when you include things like welding wire, paint etc etc.
Both cylinders were bought for £7.50 from the scrappie, which was an absolute touch! Then i had to have a custom brake line made up to join the both together. But everything else has been made in the garage.
(08-03-2014, 10:42 PM)darrenjlobb Wrote: Be interested to see what you did at the pedal end of the hydrolic setup chaps ? Good work....
It did look like the below picture at one point. But due to the stresses upon it, it was flexing too much, so has had to be 'beefed' up, to reduce a sloppy pedal feeling. I will get some more up to date pictures later on when I've got it looking a bit nicer ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png) its in bare metal at the moment.
(09-03-2014, 06:23 AM)Dum-Dum Wrote: Awesome it works ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
Yeah I'm a bit surprised myself, but, it feels lush!
Threads: 61
11
This is epic
So grant,when's the group buy starting
Threads: 169
91
