What have I bought?
![[Image: 1510830_607571512641337_272050592_n_zps81021d0f.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/1510830_607571512641337_272050592_n_zps81021d0f.jpg)
So after a 5 hour train trip I picked up the dog rough estate on Friday.
There was no head unit so I took a spare to find no speakers fitted. Lee offered to fit some he had but they were from a phase one and would have to be modded to fit as the connectors weren't the same. I was a bit short of time so had to pass.
It is every bit the dog that was advertised but it got me back home. The battery light came on a couple of times but the car kept going.
The car is very slow and loose to drive. I think the cold starting issue might be to do with bad injectors and/or HP pump. Starting issue was down to the Injectors , replaced them with cleaned nozzles 076's 03/04/15
Today I got chance to have a good look around it as on Friday evening it had got dark by the time I had got there and all I can say is it's in a bad way.
I thought I'd have a look at the fuel filter as they sometimes never get changed. When I got the lid off it didn't look too bad but I replaced it anyway. The lid was very stiff to turn and I think I could do with changing it now as it got a bit mangled.
Some of the other faults;
all door check straps need replacing, Lubricated check strap, only N/S/R needs replacing 16/02/14
drivers door hinge broken, Fixed, it was just missing bolt 14/03/14
front passenger door has been replaced but the bolts were loose, tightened bolts 15/02/14
loose battery terminal, Bodged repair to clamp 16/02/14
no remote C/L. Programmed new remote fob to car 16/03/14
Only one key. Programmed new key transponder to car
water in passenger footwell, Sealed front doors weather curtain 01/03/14
light switch on stalk broken, Replaced 15/03/14
rev counter broken, Fixed, reseated needle 16/02/14
airbag light on, Fixed, Drivers seat connection 15/02/14
ABS light on, Fixed, osf plug wasn't connected 15/02/14
hand brake warning light blown, fixed
wiper rubbers gone hard, replaced front wipers 15/02/14
clutch almost to the floor and heavy, removed assistor spring on peddle and spaced out cable on fork to raise pedal 15/02/14
Glow plug relay faulty. Replaced unit 15/03/14
dampers need replacing (offside front damper has been on the advisory of the MOT for the last 3 years), Replaced front dampers with good used dampers of a HDI Dturbo, will be using the springs too soon 13/04/14
rear discs need changing, Replaced discs and pads 14/04/14
needs fluids changing,
engine oil, Oil and filter change 21/04/14
coolant, Drained going to flush before putting new coolant in 21/04/14
power steering, Drained went took engine out 21/04/14
brake fluid,
Overdue cambelt and water pump, changed cam belt kit and water pump 217k water pump had four out of the eight vanes broken 21/04/14
thermostat, Changed thermostat 21/04/14
thermostat housing leaking, Replaced housing as the old one was warped 23/04/14
auxiliary belt need replacing, replaced with tensioner 21/04/14
missing offside skirt,
missing trim on offside wing,
dent to bonnet,
boot trim above number plate wrong colour (makes it look like the boots got a mustache),
loose front bumper,
scratch down to metal on the wing,
paint worn off offside wing mirror cap,
rear number plate delaminating,
oil marks on paint work,
NSR ach liner missing, I hope that rust spot hasn't set in.
That's just off the top of my head.
Good points;
Rear beam with no camber (Just found the rear beam and mounts to be shot 14/04/14)
Brakes work well
All the electric windows work front and back
Heater works
I was warned that it was bad. I don't know how people can let a car get so bad. I know it's not Lees fault as he only had the car around a month.
I bought it thinking I could do a bit of work on it and it could turn out to be a nice little car.
There is a lot of work to be done to get it to an acceptable standard.
The advert http://306oc.co.uk/forum/showthread.php?tid=20329
The old project thread http://306oc.co.uk/forum/showthread.php?tid=20151
My plans at this stage are to get it to a roadworthy standard then I may go stage 2.
I've ordered an R70 pump and I will be putting the old injectors out of my Dturbo in. Hopefully that will cure the starting issue. I've also got a twin pass intercooler on it's way.
I will be adding some photos later.
Edit 16/02/14
Just remembered some more faults;
Offside front and nearside front door seals worn. Replaced 15/03/14
Mist jets off a 206 or similar added so spraying at bottom of windscreen. Replaced with proper centre screen firing mist jet (15/03/14)
Mucky MAF got new VDO one fitted today.
Badly torn drivers seat. Replaced 15/03/14
Central locking a bit dodgy, drivers lock pin won't lock car and front passenger activates the locking but the lock just bounce back up. Replaced drivers door loom (18/03/14)
Rear wash jet missing.
Dodgy hand brake.
Edit 02/03/14
Found some more faults,
Drivers door damaged where check strap bolts on Bent back metal and used large washers on check strap to grip what metal is there. (18/03/14)
O/S P bush needs replacing Replaced wishbones 14/04/14
Both outer CV boots split, Replaced both drive shafts with old ones off my hatchback 21/04/14
Radiator bent but still holds coolant with out leaking, Replaced with cheap new one 21/04/14
Damaged rad fan,
Missing splash guards in engine bay,
Front fog light loose, maybe broken mounts,
Edit 16/03/14
Yet more faults;
N/S/F brake disc missing it's screws, this caused the disc to be off centre and made the car shake at 60mph. fixed 16/03/14
Turbo "air hose seal" split (1424 9L). Replaced with one from breakers 21/04/14
Squeaky heater fan.
O/S/R brake disc guard rusted loose.
O/S/F brake disc cracked.
Hand brake lever a bit dodgy.
Edit 13-04-14
Guess what even more faults
Trailing arm on drivers side loads of play. Replaced with rebuilt beam (04/05/14)
Trailing arm front bushes shot. Replaced when doing beam (04/05/14)
Rear calipers both sides main piston rubber damaged
Rear calipers both sides sliders need greasing
Hand brake cables not the best
TRE both sides have splits in the rubber
Photos that Lee took
![[Image: DSCN0305_zpsitvmcc5o.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN0305_zpsitvmcc5o.jpg)
![[Image: DSCN0304_zpsqstiqtxs.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN0304_zpsqstiqtxs.jpg)
![[Image: DSCN0303_zpsg0aqya3o.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN0303_zpsg0aqya3o.jpg)
![[Image: DSCN0302_zps4ts5kvya.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN0302_zps4ts5kvya.jpg)
![[Image: DSCN0312_zpsel72xf7d.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN0312_zpsel72xf7d.jpg)
![[Image: DSCN0306_zpsbfzxkqih.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN0306_zpsbfzxkqih.jpg)
Photos of some of the problem areas,
![[Image: DSCN8501_zpsa5eb02dd.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN8501_zpsa5eb02dd.jpg)
![[Image: DSCN8502_zpsffac9c07.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN8502_zpsffac9c07.jpg)
![[Image: DSCN8497_zpsf16cd2b6.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN8497_zpsf16cd2b6.jpg)
![[Image: DSCN8496_zps1799aa18.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN8496_zps1799aa18.jpg)
![[Image: DSCN8495_zps0628c640.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN8495_zps0628c640.jpg)
![[Image: DSCN8493_zps7bcecdce.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN8493_zps7bcecdce.jpg)
How does the paint get worn here?
![[Image: DSCN8473_zpsd2188747.jpg]](http://i984.photobucket.com/albums/ae321/Dee_306/Cars/Estate/DSCN8473_zpsd2188747.jpg)
brake fluid,
dent to bonnet,
loose front bumper,
Good points;
Brakes work well
Heater works
Edit 16/02/14
Dodgy hand brake.
Edit 02/03/14
Damaged rad fan,
Edit 16/03/14
Yet more faults;
Squeaky heater fan.
Edit 13-04-14
Seriously though, never know how people can let a car get to such a state!
![[Image: P1060836_zpsz3xgxt7q.jpg]](http://i1101.photobucket.com/albums/g427/wingnutz2/P1060836_zpsz3xgxt7q.jpg)
![[Image: Untitled_zps2ed48460.png]](http://i1179.photobucket.com/albums/x381/Luis1337/Untitled_zps2ed48460.png)
