Setting up 11mm
Bosch pump, Starts up but smokes a grey white constantly. Will idle for abit around 1k then the revs will drop to 500 and eventually cut out. When restarted will idle shit unless the throttle is held on but it smokes badly and runs quite rough and knocks quite loud. I have had a go at turning the max fuel in but just raises the idle to around 1.2k when cold and still struggles and cuts out when warmed.
Whats the trick to rid the bad smoking i believe this is the timing? Belts all good ect so is it just backwards or forwards on the bracket?
Did have a leak but fixed that so i dont believe its getting air in at all.
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
If it's timed up right advance the pump (towards engine) till smoke goes
Team Doesn't own a 306
Fuel coming out the return on idle?
Sorted Wink
www.prestige-auto-care.co.uk
Jenks bosch repairs to the rescue Wink
What was the problem in the end then? Just to help other people out if they have same issue?
Air ingress.
Banjo bolt on the advance solenoid line wasn't secure
(10-02-2014, 06:16 PM)Jenkosowls Wrote: Air ingress.
How long did it take you to work that out? 30seconds? lol the Bosch guru Wink
Any idea when my ninja pump will be ready jenks? Just asking no rush....
Have you got yours on yet chris?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
(10-02-2014, 08:27 PM)306pc Wrote: Any idea when my ninja pump will be ready jenks? Just asking no rush....
Engine not built yet lol but might be done in and running this weekend check out my project thread Wink
Yup sound thanks Big Grin I wouldn't have even checked that as I don't know what it was lol.
Blaze 1.6 Dead
