Setting up 11mm - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: Setting up 11mm (/showthread.php?tid=21239)
Setting up 11mm - HDIkyle - 10-02-2014
Bosch pump, Starts up but smokes a grey white constantly. Will idle for abit around 1k then the revs will drop to 500 and eventually cut out. When restarted will idle shit unless the throttle is held on but it smokes badly and runs quite rough and knocks quite loud. I have had a go at turning the max fuel in but just raises the idle to around 1.2k when cold and still struggles and cuts out when warmed.
Whats the trick to rid the bad smoking i believe this is the timing? Belts all good ect so is it just backwards or forwards on the bracket?
Did have a leak but fixed that so i dont believe its getting air in at all.
RE: Setting up 11mm - Danny2009 - 10-02-2014
If it's timed up right advance the pump (towards engine) till smoke goes
RE: Setting up 11mm - Tom - 10-02-2014
Fuel coming out the return on idle?
RE: Setting up 11mm - Jenkosowls - 10-02-2014
Sorted Wink
Jenks bosch repairs to the rescue Wink
RE: Setting up 11mm - Chris_90 - 10-02-2014
What was the problem in the end then? Just to help other people out if they have same issue?
Air ingress.
Banjo bolt on the advance solenoid line wasn't secure
(10-02-2014, 06:16 PM)Jenkosowls Wrote: Air ingress.
How long did it take you to work that out? 30seconds? lol the Bosch guru Wink
RE: Setting up 11mm - 306pc - 10-02-2014
Any idea when my ninja pump will be ready jenks? Just asking no rush....
Have you got yours on yet chris?
(10-02-2014, 08:27 PM)306pc Wrote: Any idea when my ninja pump will be ready jenks? Just asking no rush....
Engine not built yet lol but might be done in and running this weekend check out my project thread Wink
RE: Setting up 11mm - HDIkyle - 10-02-2014
Yup sound thanks Big Grin I wouldn't have even checked that as I don't know what it was lol.
