Threads: 374
38
Car Model/Spec: GTI 6
Picked up today, 26/02/2012
Got home to try and fit and its most definately bent, any ideas?
Left side bent..
flat side
Extended bent side
Threads: 100
Unbolt the middle make it long then rotate it. It's on a screw thread.
Threads: 374
38
Pompey306mark Wrote:Unbolt the middle make it long then rotate it. It's on a screw thread.
have done mate, i unscrewed it until it almost come off, it's still bent, and without having one end and inch above the top strut, it's not getting far..
Threads: 100
It's not bent. It was fitted to a 306 cabby before. I had the same thing with my original you just need to line it all up and bolt it down.
Threads: 374
38
Pompey306mark Wrote:It's not bent. It was fitted to a 306 cabby before. I had the same thing with my original you just need to line it all up and bolt it down.
ok, i'll bolt down the left side first, and let you know..
Threads: 448
51
Damn. Thats a hell of alot of difference
Threads: 100
Thats because it is not unscrewed and at the wront angle.
Threads: 198
135
The middle of the adjustable bit is a turnbuckle so slacken the lock nuts off and turn the middle part to extend it evenly at both ends.
Doesn't look bent to me tbh, just looks like it needs adjusting. Although it should be near enough if it was fitted to a cabby before?
Threads: 100
Threads: 100
Look at the pics in this thread you can see your centre nut is not adjusted correctly look how are apart it is compared to yours.
<!-- l --><a class="postlink-local" href="http://www.306oc.co.uk/forum/viewtopic.php?f=25&t=1825" onclick="window.open(this.href);return false;">viewtopic.php?f=25&t=1825</a><!-- l -->
Threads: 169
91
Thats a different brace though?
Threads: 374
38
was about to say... thats a slightly different shape... text incoming mark.
Threads: 100
I know, but the one in themy second post is the same as what ginge has.
It will fit he just needs to line it all up and then use a bit of force to bolts it down.
Threads: 100
Look at the link in my post after my pic please.
Threads: 541
124
My strut brace end plate look like they wont fit (and in truth they dont) but once ive got them bolted down with longer bolts the bolt pulls the plate flat with the strut top and keeps the whole thing in tension.
Threads: 100
So it fits but here are the problems. I think it would sit better on a phase 2 dturbo or hdi. All these struts sit on the brake reservoir cap my old one was the same. Did not do any damage but a pain if you want to get into the reservoir as you have to remove the strut or at least one end.
Back up for sale.
Threads: 374
38
as mark said, phase 2/3 have hydraulic lifters which dont obstruct - gay phase 1
Threads: 100
Also the bonnet is higher so will close better, unlike on the phase 1 cars.
Mine closed fine, I know its a slightly different brace, but if you look at my pic it sits in the same place as this one and at the same height.
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
Ooh, back for sale
Threads: 100
Yep will be picking it up from ginge tomorrow morning.
