Threads: 5
Quick question. ..do berlingo/partner hubs fit a 306 ...I need front hubs urgently for the hdi and have been offered a set of berlingo (prefacelift) front hubs for a very good price and dont wanna be wasting money , my front right bearing is that bad it got hot enough to melt the paint off my wheel
Threads: 136
11
Yes they will fit.
However I'm not sure how much camber you would end up with.
Are the ball joints 16mm or 18mm?
Threads: 5
I had planned to change the ball joints to suit the hub size ...I have a pair of brand ne 16mm pas ball joints and a pair of new 18mm ones here so jjst a case of figureing out geometery differences ...as long as its not going positive I can cope with a degree or so extra neg
Threads: 136
11
This is basically what happens when you put different hubs on different models.
306 hubs on 205 = positive camber
205 hubs on 306 = negative camber
Berlingo hubs on 106 = serious negative camber
Threads: 5
No camber issues after fitting ...although berlingo hubs are 16mm ball joints and lack abs sensors ...will do for the time being until I find a pair of decent hdi 18mm hubs
