Help please
Help please
I'll start from the begining as it's been a long story.
My daughters 2L HDI (1999) was cutting out, the fault codes were read and showed
P1138 fuel pressure regulator
P1112 fuel rail pressure
on advice from others I changed the HP pump but still had cutting out problems.
The fuel pressure sensor, fuel filter, fuel pump relay have all been changed.
today I changed the in-tank lift pump, after that it's still cutting out.
the code reader (MaxiDiag FR704) showed,
intermittent fault.
Diesel high pressure monitoring function.
Diesel high pressure regulator jammed.
I changed the high pressure regulator (for a known good one) and reset the the codes.
It's still cutting out and the code reader is now showing,
intermittent fault.
Lack of pressure (leak).
Could it be the O rings on the regulator as they're not looking their best ?
Or has anyone else got any ideas ?
Could be the orings, or possibly failed injector, have a read of:
http://306oc.co.uk/forum/thread-8337-post-165766.html
Just to add I've also done a leakoff test and checked the fuel cut off switch.
