106 gti front suspension
Question
Dont know if i imagined it or not but as a cheaper way of lowering can 106 gti front struts be used on a 306 and if so how much would they lower it by ?
Springs, not struts.
And it may be cheap but not suitable or safe
(23-01-2014, 07:38 AM)Piggy Wrote: Springs, not struts.
Yee can imagine they arent the best just thought id ask
Lowering springs on gti shocks come up on here for £30-50 for a pair...so its not worth trying to save a tenner
Just do it properly mate. No point messing around with parts which arent meant for the car.
why this is hear could i put the springs off my 106 (eibach -30mm) on to the 205?
Same thing dood...just do it properly
Using 106 springs on 205's is common enough, although it's usually only on the lighter TU models.
With a diesel engine 205 you're going to need different springs though - even standard 205 GTi springs lower diesels a fair amount (indeed, it works quite well coupled with a GTi spec beam and is how I ran my old 205 STDT).
I would imagine that 106 or 205 springs on a 306 would be far too low and the spring rates badly mis-matched.
106's and 205's are broadly similar weight wise, whereas a 306 is much heavier.
  Front top spring suspension Welshy_Pete 4 3,916 21-04-2018, 09:52 PM
Last Post: Mighty306
  front suspension johnnygomez 5 3,952 10-12-2016, 12:36 PM
Last Post: johnnygomez
  fitting a front suspension ball joint impotentials 3 3,901 29-10-2016, 05:46 PM
Last Post: Poodle
