Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Selling on behalf of my friend.
Made out of aluminium so very light (4.4kg per rim) 4x108 fitment will fit citroens and Peugeot and should also fit fords
£80 if gone before Tuesday, no tyres.
any questions i can relay them on or attempt to answer myself - can be delivered to the south coast area - from portsmouth - cornwall and anywhere in between on March 29th for an extra £10 or to FCS
Phaes 1 GTI 6 - Onyx Black
Threads: 92
43
Given 2 thank(s) in 2 post(s)
Steels made out of Ally? MINDFUCK
Threads: 376
38
Chris Wrote:Come with the bolts too?
bare with me
Jonny b Wrote:hhhmmnnn tempted
first some first serve...also advertised on FCS facebook page
Threads: 189
10
Car Model/Spec: E39 ACS 535i
I'm not interested in them but they do require special spinning tapered bolts.
If they are included then there a bargain!
Threads: 376
38
they don't include bolts - but as far as i'm aware, they dont require any special bolts.
Threads: 22
Car Model/Spec: 306 1.4
They look good. But are the really steels? Haha.
Threads: 189
10
There the ones off the c5, they do requier the bolts, as normal ones will eat away at the tabered bolt seats.
Only thing is the bolts are 2.80 plus the vat each!
Threads: 376
38
Chris Wrote:There the ones off the c5, they do requier the bolts, as normal ones will eat away at the tabered bolt seats.
i''ve just asked him and he says they use standard tapered bolts, no special bolts required. he ran them for quite a while.
Threads: 376
38
Kezzieboy Wrote:Picture doesn't work for me
Is it off facebook?
And if we're thinking of the same ones then it just needs tapered bolts the 'special tapered bit' is so that they work on both tapered steels and flat seated alloys Chris
yes, it was taken from facebook.
visually similar to standard alloys, but a LOT lighter and in red (cherry-ish red) for that colour you can't see
Threads: 189
10
As poodle said, I've owen 4 sets of these wheels and I know they need the bolts, end of.
There 6x15 et18
4.4kg as said
The early ones used flat bolts and are prone to cracking round the bolt holes. The later ones were revised with tapered holes awith spinning taper collers on the bolts.
Threads: 376
38
Chris Wrote:As poodle said, I've owen 4 sets of these wheels and I know they need the bolts, end of.
There 6x15 et18
chees chris - i dont/wouldnt know, only passing on messages
thanks!
