Ell Diablo - Hydraulic Clutch In
(16-01-2014, 01:18 PM)Matt Wrote: f*cking love that wink mirror!
Runs to eBay!
It's epic. It eliminates the blind spots completely. Makes driving so easy now haha
Getting there with the Welding dude. Need to slow down..gonna put me outa work Wink
lol Haha, it's by no means pretty. Looks like Stevie Wonder was let loose. Holds though Smile
Good boy Wink that's what I did with mine. After the first lot which I wedged in fell out :p
They are awesome! Ones I've seen are quite pricey though!
Thirty quid posted I think this one cost Smile
And that was from the 'States Smile
Nice! Same ones I've seen Smile
What thickness steel did you use for your switch panel btw? Need something similar for switches in the dturd lol
I used a bit of 2mm sheet ally I 'found' at work. May have one kicking about if you want Smile
Yes please if you do Smile will sort me out a treat!
No worries. When you gonna come get it Wink lmao
So picked up my seam welded subframe from dan this weekend. Top work as always.
[Image: AD277DFE-397D-480E-815D-BD10263C8794_zpsrbwhyku1.jpg]
[Image: 5539CC2D-D915-42C3-B47D-F91C28B9D45B_zps1lsp21gt.jpg]
Just gotta paint it up and fitted. Also made a start on making my upper strut brace Smile
[Image: 9790907E-DEF9-4402-894A-6F0394A26B48_zps8kjxuwsd.jpg]
ninja
Ill get it from ace next month? Smile
Subframe looks sweet! Can't wait till you have it on, see how much difference there is
Strut brace looks like its going... Urm... Well?
Haha cheers mate. All will be revealed Wink
ninja
I'm very interested haha. This car gets more interesting with every update
So just spent 70 quid on; tubular steel, nuts, bolts, aero catches and grip tape ninja
Sounds like one f*cked up bondage party!
Clearly you are too much of an amateur then! :p
Looks awesome mate! Love the work :-)
(22-01-2014, 06:55 PM)4WayDiablo Wrote: Looks awesome mate! Love the work :-)
Cheers Phil Smile
So cracked on tonight with the upper brace. Can anybody guess what's going on yet?
Mounts all dry fitted:
[Image: image_zpsab3d2492.jpg]
[Image: image_zpsda6a9c37.jpg]
Bars all welded together. Ish.
[Image: image_zps9b1ea61c.jpg]
[Image: image_zps0217e9f4.jpg]
Gotta now remove my battery box, and re-route my fuel hoses to fit this. happy days Smile
Looking handy with the welder mate!!
Now only a has been!!
www.autorite-sport.co.uk
Nice work mate Smile
Love to see lots of custom fab...
My fave bit of working on my car!
Cheers for the comments guys Smile
It definately is the best part of working in your car. Just bolting stuff on can Only get you so much satisfaction. Building something from scratch and then it all working fine, that's sense if acheivement there.
That said, I've still gotta finish it lmao might not fit :p
Well, its in!
[Image: D2B9F94E-0747-46D0-B7D2-4B04242254EF_zpspcqn27da.jpg]
[Image: 0398D7D0-F548-4904-906A-EF771CDA4784_zps1jdgno50.jpg]
All fits, snug as a bug. Just gotta paint it now.
You sure that the engine won't touch that as rocks/moves slightly coming on and off the power? Might be plenty of clearance there and it's just the photo that makes it look tight, but worth keeping in mind as engines do move a surprising amount on standard mounts.
(24-01-2014, 12:27 PM)powerandtorque Wrote: You sure that the engine won't touch that as rocks/moves slightly coming on and off the power? Might be plenty of clearance there and it's just the photo that makes it look tight, but worth keeping in mind as engines do move a surprising amount on standard mounts.
I'm pretty confident it will be fine Smile
I have welded in 5mm steel on either side of the engine mount so there it very little movement at the top of the engine there. There is about 10mm between the engine and the brace. I think the angle of the photo isn't the best.
Boom!
[Image: 9E4D4DE9-B531-48F1-A336-01C061F3CD9B_zpsfyoy6tgn.jpg]
S16 engine ɑnd box grant! 70
[Image: SDC10442-1.jpg]
That looks awesome painted up!
Thats f*cking cool! Iirc Grants got a solid lower engine mount so i cant see the engine moving that much.
Users browsing this thread: 18 Guest(s)
