Engine Rebuild question
Rebuilding a xud9 engine. What piston rings do you recommend?
Thank you!
Peugeot oem ones!
Has anyone tried any other piston rings than oem ones? Not in my budget the oem ones. Also i see the compretion ratio for the xud9 is 21.8. What is that in bar/psi?
don't cost cut when bulding an engine it will only bite you in the arse in the long run
Not on an XUD - but used Total Seal rings when I did my GTi-6.
http://www.totalseal.com/
JP
JP
A ratio is ratio, doesn't have a unit
Ok. 26 bar on 2 pistons and 27 bar on the other two. Is is ok or change the piston rings?
compression @ 26bar sounds good to me
Again like Jammapic it's not XUD's specific experience, but I've always found a good quality aftermarket piston ring set is fine. On the petrol XU rebuilds I've carried out I've used Federal-Mogul rings which are readily available and typically much cheaper than OE.
Big Grin 405 overhaul and engine rebuild 405D-turbo 4 3,768 16-11-2015, 11:41 PM
Last Post: daveylennon93
  engine rebuild questions blinkyeatu 1 2,434 03-03-2015, 01:21 AM
Last Post: Dave
  Help Needed On Engine Rebuild (Companies) Lwilliams 12 6,290 16-12-2013, 06:58 PM
Last Post: Lwilliams
