266mm upgrade
266mm upgrade
what do I need to change my standard dturbo 240mm to 266mm
[Image: cornishmafia.jpg]
Callipers, discs and pads. Got the lot for £60
so just calipers I got 266mm ebc discs
I have two set ups here, both 266 one I want to keep complete.
Got a set of calipers that came of the last car I was breaking just sat here yours for £20 posted Via Parcelforcre 24H
Chris
Yeah If your looking for just callipers send me a pm Smile
Giving it away ay u chris?
As said you will need discs and pads that are for the caliper. Also 1 note when fitting clean the threads in the hubs for the carrier bolts as the brake carrier for the 266 calipers is a bit thin so the bolts need to go further through.
Also standard d Turbo brakes are 247mm
get gti6 brakes instead. probably cost you the same. Theyre all cheap now.
Do you need the upgrade master cylinder
Not for 266s its recommend for 283gti brakes tho
[Image: av5ym8.jpg]
