266mm upgrade - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: 266mm upgrade (/showthread.php?tid=20291) |
266mm upgrade - paul7278 - 09-01-2014 what do I need to change my standard dturbo 240mm to 266mm RE: 266mm upgrade - underground375 - 09-01-2014 Callipers, discs and pads. Got the lot for £60 RE: 266mm upgrade - paul7278 - 09-01-2014 so just calipers I got 266mm ebc discs RE: 266mm upgrade - Chris1357 - 10-01-2014 I have two set ups here, both 266 one I want to keep complete. Got a set of calipers that came of the last car I was breaking just sat here yours for £20 posted Via Parcelforcre 24H Chris RE: 266mm upgrade - underground375 - 10-01-2014 Yeah If your looking for just callipers send me a pm Giving it away ay u chris? RE: 266mm upgrade - Frosty - 10-01-2014 As said you will need discs and pads that are for the caliper. Also 1 note when fitting clean the threads in the hubs for the carrier bolts as the brake carrier for the 266 calipers is a bit thin so the bolts need to go further through. Also standard d Turbo brakes are 247mm RE: 266mm upgrade - Eeyore - 10-01-2014 get gti6 brakes instead. probably cost you the same. Theyre all cheap now. RE: 266mm upgrade - paul7278 - 10-01-2014 Do you need the upgrade master cylinder RE: 266mm upgrade - Jimbo - 10-01-2014 Not for 266s its recommend for 283gti brakes tho |
