Xantia engine
Xantia engine
managed to find a xantia engine, comes with bosch, but its one of those semi ecu controlled bosch pumps, if i was to put ine on would it run fine? also what engine code is it most likely going to be? its from an N-M plate.
Yeah it'd be fine with a normal pump on, no idea of engine code though
i reckon dhx/dhz even?
I think all semi ecu Xantia/406's are DHX arent they? And agree with Connor, your pump would run fine on it.
PS. cant really call me atm as im in the office, hence being on 306oc ninja But I assume this is what you wanted to ask?
Yes dan, thanks Smile
150quid for complete engine, bosch, turbo, box etc.
av just got one same padge complete for 150quid Smile
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
Good price aint it mate, yours is a 306 one though, mines from a xantia comes with inlet etc.
yeah true mine is from a 306 Smile
Getting the DHX working in a 306 is a bit of a bitch, lot of stuff needs swapping over... pump should be ok though so long as you swap EVERYTHING, including the pump bracket etc.
JP
JP
Thats the plan Smile
  Xantia engine questions Frosty 30 14,085 27-03-2014, 12:02 PM
Last Post: ally406
  Breaking 306 dturbo + xantia engine and td04 petegledhill 30 17,086 03-12-2012, 10:58 PM
Last Post: David
