16-12-2013, 11:19 PM
got one of these, but cant find out the exact size, 2052/54/56? tried a few turbo sites trying to find it but nothing really about, anyone know the size?
mercades c250 gt20
16-12-2013, 11:21 PM
on one site, it said they come with a gt25C, but I think that's a twin turbo one? that's what it said anyway, but mine was listed as a GT20.
16-12-2013, 11:33 PM
Gt25c is a 52mm but old style turbine wheel iirc... So has a t series turbine and gt series 52mm compressor.
That's before they went to the new GTXXYYZZZ naming scheme, so GT25 means nothing.
16-12-2013, 11:34 PM
so what would those be like on an xud? I could of had one for £99 but decided against it and got the gt20 instead, much difference between a 52 and a 56?
30-12-2013, 12:48 PM
Run a touch higher boost with a 56, 52's die over 25psi as the shafts on them are too thin for any more stress.
30-12-2013, 01:05 PM
56s die too...just ask pellowe
the mercs after the the early gt25s are gt2052s £99 is around average of what I have seen on the bay...seem some as cheap as £75 Wishes for more power...
30-12-2013, 02:30 PM
don't forget about flow, standard t2 might do 20 psi+ but it wont flow anywhere near as much as this thing at 14 even.
30-12-2013, 02:32 PM
(30-12-2013, 02:30 PM)welshpug Wrote: don't forget about flow, standard t2 might do 20 psi+ but it wont flow anywhere near as much as this thing at 14 even. I rekon by the difference the T2 on Ozones xud11 compared to my GT2056s, it flows twice as well, and gets on boost sooner too...and then continues to flow once the T2 is out of puff, which is quite soon even at 30psi Wishes for more power...
30-12-2013, 03:56 PM
My gt2052 flows more at 5-7psi than a t2 does at 20psi
Peugeot 206 GTI HDI
Volvo V50 2.0d Volvo XC90 D5
anton, whats yours go like? and when does it hit full boost?
and whats your clutch hold like?
31-12-2013, 06:44 AM
Hitting 20psi just over 2k. 25-27 by 2.2k. Clutch has held fine. Standard valeo with about 15k miles on it, now about 25k.
Peugeot 206 GTI HDI
31-12-2013, 08:47 AM
Im on standard valeo too with the 2.1 n gt2056... No hint of slip yet
31-12-2013, 03:51 PM
Think we need some dyno results off people running this turbo, to see what its capable of?? unless ive missed some ones results?
I no ruans but that was vnt, whos done one with the non vnt one?
31-12-2013, 03:53 PM
I think ruans was a 1752?
I may go for a run in Feb, once back off holiday and earnt some dollar Wishes for more power...
31-12-2013, 04:01 PM
(31-12-2013, 03:53 PM)Piggy Wrote: I think ruans was a 1752? No he had a gt20v under his sig ( Black GT20V XUD9TE 306 Ph2 DT - Sorely Missed. ) Sure it pulled in the 300ftlbs of toque, but guessing you guys haven't got that kind of toque cos you would be slipping the clutch by now? Or am i wrong
Yeah Ruans was a gt2052v and he is the only person so make 300ftlb in an xud, well im sure he was the first someone might have beat him by now!
I think he put a gt17v in the moonstone thingy.
01-01-2014, 12:07 AM
You'll get more torque from a gt20 than a td04 all day long
01-01-2014, 12:28 AM
(01-01-2014, 12:07 AM)Piggy Wrote: You'll get more torque from a gt20 than a td04 all day long Surely not more? Maybe sooner in the rev range, and sustained for longer.
01-01-2014, 12:45 AM
(01-01-2014, 12:28 AM)Tom Wrote:(01-01-2014, 12:07 AM)Piggy Wrote: You'll get more torque from a gt20 than a td04 all day long Power equals torque/RPM.. TD04 will pretty much always make less torque, go look at the figures... My black DT had a GT2052v on... Made 313lb.ft torque.. My blue DT had a GT17s from James Aston with a screwed up hotside...
01-01-2014, 07:04 AM
i got one one of these a couple of months ago, and just got round to mating it up with a manifold, and adaping a td04 actator to fit. i will get some pictures up.
how were you going to do the exhaust side? ive got a 3" elbow and flexi and i was thinking of getting a v-clamp and making a flange to weld on to the elbow, instaed of just welding the elbow the hotside
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning) 205 STDT -new project
02-01-2014, 08:09 PM
Oh you're in Bicester?! I'm just in Kirtlington... We should meet up at some point..
Take a look at Rickys project thread, he used one also, used a v-band welded to an elbow, it's the way forwards as you can set the angle easier, otherwise you'll set it slightly off and it'll be under strain 24/7!! |
| gt20 exhaust system | Chris_90 | 13 | 8,080 |
15-10-2014, 07:42 AM Last Post: Mike |
| Gt20 | sherman306 | 32 | 20,023 |
14-03-2014, 05:23 PM Last Post: Chris_90 |
| TD04 to GT20 oil feed | anto | 11 | 8,100 |
07-03-2014, 11:46 AM Last Post: anto |
