oil cooler...need it?!
ok...so as some may know I have had constant issues with my oil cooler...some my own doing...some not.
But do I need one??
Oil temp never goes above 95degrees on the gauge no matter how hard I drive it
Im thinking of sacking it off and plumbing the heat exchange unit back in
Huh
Ooooor you could have it hanging out the front grille in a rat esq style.
That would be big WIN!
err no
You say the oil temp never goes over 95degrees, but is that with the cooler or not? If it is with cooler I would expect the tempture to raise with out it, I'm looking at oil cooler for 205 so will keep my eye on this thread Smile
I considered running an oil cooler but my temps only hover around 95 degrees even after a blast.
I'd disconnect the pipe work and trial the heat exchanger.
Thats what Im going to do.
it nornally sits around 85/90.
But when the car was overheating all the time it still never went above 95...hit it once.
Whats the sort of temp it should be at?!
Christ, I could quite easily see 120*C+ oil temperatures after a brief hoon.
You should ALWAYS keep the heat exchanger - that's because it warms the oil up faster also, it's a two way thing of heating the oil when cold quicker and cooling it down when it's hot...
You want the oil temperatures around the 90*C mark during normal running to allow any water that's gotten in to eventually steam off...
cool...
It was a secondary question that I wonder if the oil cooler was keeping things too cold!
thanks for input ruan
Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles?
(13-12-2013, 02:25 PM)Ruan Wrote: Christ, I could quite easily see 120*C+ oil temperatures after a brief hoon.
Probs my crappy guage, though I have a homebrew/hybrid cooling system Wink
(13-12-2013, 04:19 PM)Sambarker Wrote: Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles?
coz they are line £50...
and its done nothing but drop oil because of it!!
this car is supposed to be a reliable GT not a track weapon!
Heh id deffo say keep it...Without a cooler my car would last about 10 minutes on boost...the oil gets raped in big turbo dervs...
[Image: sigi-2.png]
keep it, why are you having issues mate? my mocal cooler was fine, never leaked once!
I suppose £50 is a lot of money to spend for some people.
Perhaps if you had proper pipes made up it might be better. I don't recall mine leaking once.
I can't understand anyone having issues with oil cooler hoses unless they're jubilee'd
Which they shouldn't be.
Jubilee clipping HP oil lines is a recipe for disaster.
That seems quite low after a thrash mine goes up from 90ish to well above 110 after even a short blast
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Hmmm interesting, without a cooler my oil doesn't seem to get that hot - 150F ish cruising and maybe 190F after a hoon
so whats that 60 - 90 Celcius?
I always planned to fit one to my boosted XUDs but never got round to it, it's up for sale though Wink
Stage 2 XUD Sedan
(13-12-2013, 09:15 PM)Ruan Wrote: I can't understand anyone having issues with oil cooler hoses unless they're jubilee'd
thats not the issue I have had this time!
see my other thread!!
