oil cooler...need it?! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: oil cooler...need it?! (/showthread.php?tid=19554) |
oil cooler...need it?! - Piggy - 13-12-2013 ok...so as some may know I have had constant issues with my oil cooler...some my own doing...some not. But do I need one?? Oil temp never goes above 95degrees on the gauge no matter how hard I drive it Im thinking of sacking it off and plumbing the heat exchange unit back in ![]() RE: oil cooler...need it?! - Lego Jon - 13-12-2013 Ooooor you could have it hanging out the front grille in a rat esq style. That would be big WIN! RE: oil cooler...need it?! - Piggy - 13-12-2013 err no RE: oil cooler...need it?! - Chris_90 - 13-12-2013 You say the oil temp never goes over 95degrees, but is that with the cooler or not? If it is with cooler I would expect the tempture to raise with out it, I'm looking at oil cooler for 205 so will keep my eye on this thread ![]() RE: oil cooler...need it?! - mr_fish - 13-12-2013 I considered running an oil cooler but my temps only hover around 95 degrees even after a blast. I'd disconnect the pipe work and trial the heat exchanger. RE: oil cooler...need it?! - Piggy - 13-12-2013 Thats what Im going to do. it nornally sits around 85/90. But when the car was overheating all the time it still never went above 95...hit it once. Whats the sort of temp it should be at?! RE: oil cooler...need it?! - Ruan - 13-12-2013 Christ, I could quite easily see 120*C+ oil temperatures after a brief hoon. You should ALWAYS keep the heat exchanger - that's because it warms the oil up faster also, it's a two way thing of heating the oil when cold quicker and cooling it down when it's hot... You want the oil temperatures around the 90*C mark during normal running to allow any water that's gotten in to eventually steam off... RE: oil cooler...need it?! - Piggy - 13-12-2013 cool... It was a secondary question that I wonder if the oil cooler was keeping things too cold! thanks for input ruan oil cooler...need it?! - Sambarker - 13-12-2013 Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles? RE: oil cooler...need it?! - mr_fish - 13-12-2013 (13-12-2013, 02:25 PM)Ruan Wrote: Christ, I could quite easily see 120*C+ oil temperatures after a brief hoon. Probs my crappy guage, though I have a homebrew/hybrid cooling system ![]() RE: oil cooler...need it?! - Piggy - 13-12-2013 (13-12-2013, 04:19 PM)Sambarker Wrote: Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles? coz they are line £50... and its done nothing but drop oil because of it!! this car is supposed to be a reliable GT not a track weapon! RE: oil cooler...need it?! - darrenjlobb - 13-12-2013 Heh id deffo say keep it...Without a cooler my car would last about 10 minutes on boost...the oil gets raped in big turbo dervs... RE: oil cooler...need it?! - padge - 13-12-2013 keep it, why are you having issues mate? my mocal cooler was fine, never leaked once! oil cooler...need it?! - Sambarker - 13-12-2013 (13-12-2013, 04:55 PM)Piggy Wrote:(13-12-2013, 04:19 PM)Sambarker Wrote: Why not get a thermostatic plate or an in line oil thermostat before the cooler that way you've covered all angles? I suppose £50 is a lot of money to spend for some people. Perhaps if you had proper pipes made up it might be better. I don't recall mine leaking once. RE: oil cooler...need it?! - Ruan - 13-12-2013 I can't understand anyone having issues with oil cooler hoses unless they're jubilee'd Which they shouldn't be. Jubilee clipping HP oil lines is a recipe for disaster. RE: oil cooler...need it?! - HDIkyle - 14-12-2013 That seems quite low after a thrash mine goes up from 90ish to well above 110 after even a short blast RE: oil cooler...need it?! - zx_volcane - 14-12-2013 Hmmm interesting, without a cooler my oil doesn't seem to get that hot - 150F ish cruising and maybe 190F after a hoon so whats that 60 - 90 Celcius? RE: oil cooler...need it?! - strictly_perv - 14-12-2013 I always planned to fit one to my boosted XUDs but never got round to it, it's up for sale though ![]() RE: oil cooler...need it?! - Piggy - 14-12-2013 (13-12-2013, 09:15 PM)Ruan Wrote: I can't understand anyone having issues with oil cooler hoses unless they're jubilee'd thats not the issue I have had this time! see my other thread!! |
