Vibration
Vibration
1st I have a vibration frew the gear stick steering wheel and pedals pretty much all the time since I lowered my car 60mm hope someone has came across this before cheers lads
Something must be fouling, have a look around. Start with bits that were taken off or will have changed position relative to the chassis when you lowered the car - exhaust, wishbones, driveshafts, etc.
lower engine mount.
check first what has changed...
As piggy said above, the lower engine mount can cause this, i had the same problem and i changed the lower engine mount and the gearbox one and all smooth again.
I would look first at what you have changed recently if you have just lowered it, and it didn't do it before.
  Engine Vibration Felt Throughout Revs Tom85 2 2,176 21-12-2013, 08:00 PM
Last Post: Tom85
  rattley vibration sort of sound dan wiltshire 5 3,730 03-12-2012, 02:02 PM
Last Post: dan wiltshire
