Drivers side full beam won't work??
Bulb works
Wires all seem to be intact and seem to have good enough connection
What else could it be ?
how do you know bulb works? tried it in other side? . Smile
Put it to a battery charger..
check the fuse in the fusebox under the bonnet
Fuse?
But would a fuse not cause both not to work ?
fonts have seperate fuses for left/right, dip and main beam
Happy days must check them when I get out of work thanks Smile
Fuse was blown sorted now thanks Smile
  Fuel guage stuck on full, but returns to zero with engine off. Will red light work? Charlie0 6 5,127 11-09-2018, 10:11 PM
Last Post: Charlie0
  passenger headlight not going full beam?? RichyMRX 7 3,874 30-09-2014, 09:18 AM
  Finally set about the drivers side door loom! wacker315 3 2,930 17-09-2014, 04:35 PM
Last Post: cully
