Clutch feels stiff!
Just brought my 306 two days ago and the cutch feels extremely stiff! Could this be because the car has been parked up for a long time or is it something I should be worried about? and also can anyone recommend where I could get service parts at good prices from, car needs a full service and im on a student budget! Blush
They are heavey compared to most cars. Service stuff try Opie Oils, they're very good they do kits with everything in one go.
Get use to it.....
Mines really light for a xud a new cable may lighten it up? No guarantee though
Team Doesn't own a 306
they should not be heavy, that certainly is not "how they all are" most common cause is actually the bushes on the cross shaft in the gearbox have worn and the shaft is rusty, coupled with a tired clutch cable, also tired pressure plate springs will become stiff.
You can't say that 306 clutches are not notoriously heavy? I changed everything on my '6. Gear box, clutch (genuine), cable, and yes, bushes too. It was lighter for about 5 minutes...
Heavy clutch is standard issue on all 306's.
no it certainly is not, you should feel the clutch on my gti6 engined ZX 16v, granted it is not feather light without feel like anything modern, but it sure isn't "heavy"
clutch on my GTI6 is light compared to my HDI, hdi feels real heavy
Lose the spring behind the clutch pedal, it's prob full of poo. Helped mine.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
  Really stiff gearstick djyo 30 17,818 05-04-2018, 05:56 AM
Last Post: mangler
  stiff lower gears selection Magenta Sunset 3 2,752 15-01-2016, 12:18 PM
Last Post: bashbarnard
  Rear beam stiff on one side WILL1000 14 6,878 23-08-2015, 10:05 PM
Last Post: Jonny81191
