Threads: 465
114
Car Model/Spec: Vauxhall
have you looked at the head yet?
i think i would leave questions untill ive seen the valve/head face's
but yes you can put the head on another block but check the head is flat and true first
Threads: 151
14
Car Model/Spec: 306 D-turbo
Not yet just stripping I down now obviously if there's marking its scrap but if it seems ok and it's not
Warped be ok to bolt back on Dosent need skimming again?
Team Doesn't own a 306
Threads: 41
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
If it was fine before as long as its not cooked and no pistons destroyed it no reason it shouldn't still be fine just check it with a flat gauge
even without seeing it I cant imagine it will be in great shape after such catastrophic bottom end failure
Threads: 151
14
Is tons are destroyed at the bottom the crown is fine and no sign of valve damage seems ok
Threads: 90
Only damage ive ever done is bend valves....rod failure at worst will just put piston up against the valve, but in general this donst even happen due to boost blowing the pistons down the bores, hence why the pistons all end up munched up up the bottom first...
No reason to need to skim it unless you cooked it, which you didnt.
