Skimming head - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Skimming head (/showthread.php?tid=18462) |
Skimming head - Danny2009 - 30-10-2013 As most of you know I've spat a rod or 2 When I built the engine I had the head skimmed and new valve stem seals put in Question is will it need skimming again or cani just clean it up put a new headgasket on and bolt it onto a block with more conrods and less holes ![]() Cheers RE: Skimming head - cully - 30-10-2013 have you looked at the head yet? i think i would leave questions untill ive seen the valve/head face's but yes you can put the head on another block but check the head is flat and true first RE: Skimming head - Danny2009 - 30-10-2013 Not yet just stripping I down now obviously if there's marking its scrap but if it seems ok and it's not Warped be ok to bolt back on Dosent need skimming again? RE: Skimming head - Dave - 31-10-2013 If it was fine before as long as its not cooked and no pistons destroyed it no reason it shouldn't still be fine just check it with a flat gauge RE: Skimming head - Piggy - 31-10-2013 even without seeing it I cant imagine it will be in great shape after such catastrophic bottom end failure RE: Skimming head - Danny2009 - 31-10-2013 Is tons are destroyed at the bottom the crown is fine and no sign of valve damage seems ok RE: Skimming head - darrenjlobb - 31-10-2013 Only damage ive ever done is bend valves....rod failure at worst will just put piston up against the valve, but in general this donst even happen due to boost blowing the pistons down the bores, hence why the pistons all end up munched up up the bottom first... No reason to need to skim it unless you cooked it, which you didnt. RE: Skimming head - Danny2009 - 31-10-2013 Thought it would be ok to bolt back on due to hg not going ect but just wanted it clearing up Cheers lads
