Won't rev amongst other things
Having issues with the car
Won't rev past 3.5-4k gov is shimmed solid so is not that, it drives like it's not goved
White smokes the street out when cold and hunts like its on veg
Fuel filters clean and so is the strainer
Only ran on shell diesel
Warm or cold it smokes white and diesel knocks Dosent smoke as much when warm only when revving the engine, fires straight up when cold but smokes so it's not glowies
Tried advancing and retarding pump makes no if little differance
Anyone have any ideas?
Team Doesn't own a 306
timing out on belt? . . .
Good shout ill check that what would cause it to stop reving tho
Mines been doing this since I bought it and more recently strange noises are coming from the pump/belt so it would well be timing. I need to get mine checked when the Bosch goes on.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Just don't understand how it won't rev under load or idle just won't do it
Seriously thinking about breaking it (que the vultchures)
When mine wouldn't rev at all it was the gov that went into pieces in the pump. Think Jenk still has the remainder of the pump full with springs and washers lol
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Don't think it's that pal took the gov out other day,
It revs round to 5k now at idle but pops like a petrol backfire and when you let off the revs if won't idle just cuts out then runs like shit on start up
Sorry I meant mine smokes white and hunts even on diesel like yours but it doesn't stop it reving - not that I can see what its reving to as I have no tacho.
S14 Zenki Build
Timings fine
Sure you got throttle arm on ok. Check injectors too
Ph3 perv cab heaven
Black ph1 XUD died
That sounds like the timing stuff inside the pump is f*cked, take the lid off again and check your gov is still there lol
I had the top off last Saturday it was still there and it was doing it before but another look won't hurt
Is the actually timing of the derv pump ok?
Sorted it, stripped the threads on the studs the pump goes on so wasn't nipping up properly and pump was moving about
Replaced the studs and it's ok now
You must of been bollocking them up then!
But yeah that would cause your problem
Yea bit heavy handed like things tight
Ahh well live and learn least it's sorted
I've learnt my lesson many times, snapped wheel bolts mainly and a couple of caliper bolts Big Grin
nice one mate good to hear...
