10-10-2013, 06:31 AM
so what was the 10mm fuel filter from if you dont mind sharing?.
205 dt sleeper, engine in :)
10-10-2013, 07:31 AM
10-10-2013, 10:23 AM
(10-10-2013, 07:31 AM)zx_volcane Wrote:(10-10-2013, 06:31 AM)Piggy Wrote: so what was the 10mm fuel filter from if you dont mind sharing?. yeah...but it doesnt work!
10-10-2013, 10:47 AM
(10-10-2013, 10:23 AM)Piggy Wrote:(10-10-2013, 07:31 AM)zx_volcane Wrote:(10-10-2013, 06:31 AM)Piggy Wrote: so what was the 10mm fuel filter from if you dont mind sharing?. http://www.inlinefilters.co.uk/Filters-F...FFG-FF5079
11-10-2013, 04:08 PM
Xsara Vts rack going on tomorrow
11-10-2013, 08:02 PM
12-10-2013, 06:02 PM
I've got a xsara rack with PAS on the gti, bloody love it!
Just found a couple of oil leaks on the dt engine ![]() Think both ends of the crank are leaking and I think the oil feed to turbo is leaking too ![]() Although it doesn't seem to be from the crank seal timing belt end?! The oil is higher up. Unless it's leaking through from the oil feed for turbo No trace of oil on the belt either
23-10-2013, 07:06 AM
back of rocker cover is often case or oil feed/return
23-10-2013, 09:53 AM
Really great little project, and done properly too, love it!
24-10-2013, 07:55 PM
Picked up an 11mm pump earlier
thanks again.
24-10-2013, 09:38 PM
11mm's are where it's at Paul
Need a catch up again soon. You should try come to the ace meet.
Stage 2 XUD Sedan
25-10-2013, 03:45 PM
Got a td04 on the way too
Why are dervs so addictive Is that French night or 306oc night?
25-10-2013, 06:45 PM
Classic and performance french car night. Next one is 18th November
26-10-2013, 09:10 AM
cool, will try and remember
26-10-2013, 03:40 PM
28-10-2013, 06:51 PM
Anybody got any ideas of the difference in springs?
I can't get the LDA boost pin out as the fuel pin has stuck a bit. Fitted the 11mm pump yesterday with thanks to Ryan and the difference is phenomenal. I've kept my LDA pin and pump head to save swapping a few bits over. Bad bits about the pump is that the solenoid is sticking open when I take the key out. Gov cradle was cracked so had to use mine LDA pin was a bit bodged and running on the side of the ramp. Throttle arm seal was leaking but all is well now. A few pics ![]() What the boost hose said to the 11mm pump
28-10-2013, 08:40 PM
Well going from a maxed out 9mm to 11mm, it's a huge difference!
28-10-2013, 09:15 PM
The 11mm's have huge potential. They are engine killers though if your not careful.
Stage 2 XUD Sedan
28-10-2013, 11:09 PM
Much smokier or no? In what way has the drive changed? I know they're supposed to have more top end power, so to speak.
29-10-2013, 09:41 AM
Has the old spring not just been stained by blow-by? That looks like burnt on oil to me, same as old dipsticks.
30-10-2013, 06:35 PM
It's not stained mate, 100% it's 2 different springs.
Feels like a got masses more torque over the 9mm, pulls well every time where the 9mm was a bit hit and miss.
31-10-2013, 06:06 AM
T2 on there at the mo
31-10-2013, 07:11 AM
looking good
sounds like you got a bit of a lemon with the 11mm pump but glad you got it all sorted now. you think the 11mm is good now.. wait till you get a turbo to give the needed air....oh my lady gaga Wishes for more power...
31-10-2013, 07:16 AM
I'm not complaining about the pump, you'll always find problems with things.
Just saved me finding an 11mm pump and swapping the bits over. Going to pick up an engine weekend after next to rebuild and stick some hdi conrods in and possibly might go for head studs too. What's the safe limit of boost on a td04? That turbo I've acquired has got a genuine 65k on it and has always been looked after, also need a oil line if someone can point me in the right direction
31-10-2013, 07:23 AM
most peeps just weld the wastegate shut. 30psi most run at.
its out of the efficiency range and thus a bit pointless imo but the td04 is a hard ass and will take it Wishes for more power...
31-10-2013, 04:18 PM
31-10-2013, 05:53 PM
I've been told by some people that welding the waste gate shut is a big no no?!
| Hi, building VNT'd 205 Sleeper in Chesterfield... | 399road | 145 | 135,766 |
09-02-2019, 07:52 AM Last Post: Chris_90 |
| Citroen Dispatch Sleeper Kind of.. | Will | 2 | 3,613 |
15-02-2017, 07:24 PM Last Post: Poodle |
| A Street Sleeper is reborn! THE END | procta | 621 | 452,659 |
07-12-2016, 02:53 PM Last Post: Piggy |
