Aerial help?
Having a bit of bother with the car radio, the FM/AM doesn't work at all now, used to work a bit, but now it doesn't.
I have put a new aerial wire in (both bits) but doesn't seem to have made any difference,
anything i should know about? or is the general 306 aerial just plain wank?
I have an in car Arial fitted on the front window I am Shure it is a Halfords one only cost £4 works relay well
Standard aerial has always been more than adequate for me, brand new genuine ones are only ~£15 if you fancy trying that next. Don't suppose it could be getting interference from anything, break in the sheathing etc..?
Iirc the aerials are supposed to be powered from the standard HU for better reception
Remember seeing a guide for adding a regulator on here somewhere but can't remember who's it was
I could do with this. Mines snapped! Sad
If you're using an aftermarket headunit get the longer aerial from a ph1 and you'll get your stations back.
Even with the reg mod the ph3 isn't that good, the ph1 aerial picks up better a lot better reception.
Ah cool. I'll do this monday
  Do I need a new aerial for DAB radio? DonGonzo 1 2,903 15-04-2022, 07:29 PM
Last Post: Mighty306
  306 Cab aerial repair Aussie306Cab 0 2,785 19-01-2021, 03:40 AM
Last Post: Aussie306Cab
  Snapped Aerial Mark 2 2,823 08-09-2014, 09:20 PM
Last Post: Mark
