Help ph3 heater stuck on hot
Hi anyone have any idea about the heater always blowing hot air out it makes no difference where the dial is put hot or cold the blower works fine any ideas thanks.
Look under the dash in the passenger footwell, behind the centre console. There's a small two pin plug that controls the diverter flap, mine was stuck on hot when this was disconnected.
The circular switch in the dash may have become disconnected from the cable pulls inside.
May require the heating control console replacing. Relatively easy to replace, and cheap to pick-up the part from a scrappy.
