Help ph3 heater stuck on hot - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Help ph3 heater stuck on hot (/showthread.php?tid=17406) |
Help ph3 heater stuck on hot - vtec power gt - 17-09-2013 Hi anyone have any idea about the heater always blowing hot air out it makes no difference where the dial is put hot or cold the blower works fine any ideas thanks. RE: Help ph3 heater stuck on hot - cwspellowe - 17-09-2013 Look under the dash in the passenger footwell, behind the centre console. There's a small two pin plug that controls the diverter flap, mine was stuck on hot when this was disconnected. RE: Help ph3 heater stuck on hot - Pipps - 03-10-2013 The circular switch in the dash may have become disconnected from the cable pulls inside. May require the heating control console replacing. Relatively easy to replace, and cheap to pick-up the part from a scrappy. |
