Over boosting ???
Over boosting ???
I've finally sorted my problem out with this under boosting issue but now I have it boosting at 26 psi when in 4th with my foot down is that too much so should I turn it down a little ?? If feels like it's got not to give but it's missing something and I don't no what it is ??
No such thing as "over boost" on an XUD.
Man the f*ck up!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(21-09-2013, 01:08 PM)silverzx Wrote: No such thing as "over boost" on an XUD.
Man the f*ck up!
Hahahaha just read the title and in my head said theres no such thing and you beat me to it!
(21-09-2013, 01:00 PM)Dan306DT Wrote: I have it boosting at 26 psi when in 4th with my foot down is that too much so should I turn it down a little ?? If feels like it's got not to give but it's missing something and I don't no what it is ??
yeah its called 5th gear Tongue
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
If you have boost, and no poke, you need more smoke.
That worked for me on the 405 I had anyway Tongue
What's it like in other gears?
There's smoke and some poke fuel pumps up as much as it will go xx
as I said dump the clutch move to 5th and put your foot down again and tell us the results Tongue
29 psi haha
whats wrong?!
Im confused Huh
(21-09-2013, 03:55 PM)Dan306DT Wrote: 29 psi haha
*facepalm*
I think they meant, does the car start accelerating again. lol
As in, you're revving it too hard. In diesel, revs are bad. Boost, torque and low revs are good Big Grin
*facepalm*
Revving a diesel hard isn't that bad!
@op. 26 is OK, its at the limits
*facepalm*
True, but it's not that efficient? Saying that, my NAD got to 5000rpm on the rollers and the HP still hadn't peaked. Got to 61hp. Tongue
if its burning fuel cleanly and continuing to make power....then its efficient
(21-09-2013, 10:09 PM)Piggy Wrote: if its burning fuel cleanly and continuing to make power....then its efficient
We're talking about XUDs here Tongue I meant generally. Big Grin
If you don't need all the boost to burn all the fuel you're supplying, then more boost than required places more strain on the turbo and intercooling system... Also the pumping losses of the engine having to compress even more air in the cylinders is kinda pointless... Turn it down to the sweet spot of no smoke, but not higher than it need be.
thats a pretty general rule to be honest.
people would say an evo8 that produces 400bhp is really inefficient...
well 25mpg isnt great...but its efficient when you consider the amount of power it produces for the fuel it uses
(22-09-2013, 08:40 PM)Piggy Wrote: thats a pretty general rule to be honest.
It's not 25mpg when it's producing 400hp though, so it is inefficient?
An Aston Martin can do 25mpg and produce the same power. (6.0 V12)
Not a valid argument, but the Aston would probably be more efficient at high rpms than an evo producing the same power. I go off topic no more. Tongue
exactly. so aston have to use 3 times as many cylinders and 3 times as much capacity to get the same power.
an evo isnt a great example to be honest...more modern turbo petrols and diesels would be better to demonstrate but its still valid
(22-09-2013, 09:43 PM)Piggy Wrote: exactly. so aston have to use 3 times as many cylinders and 3 times as much capacity to get the same power.
Trust me, NA power delivery is so much better, 12 cylinders sounds better too, less stress on engine parts as well so longer life Big Grin
Every car should be a V12.
(23-09-2013, 07:33 PM)Martin306 Wrote: Every car should be a V12.
This^
but consider the price!!
can you get a v12 vantage or db9 for 7grand!?
You might get a DB7 for that if you know where to look Wink Or a Jaguar XJ-S with IDF Weber (same car but SOHC)
Anyways, I'll post no more. I'm trying to stay away from spamming. Rofl
nah I spam till get told off!!!
db7s are pretty...but just pretty xjs's. which are a rubbish car imo. And I love jags! lol
(23-09-2013, 09:02 PM)Piggy Wrote: nah I spam till get told off!!!
db7s are pretty...but just pretty xjs's. which are a rubbish car imo. And I love fags! lol
Bit off topic?! Wink
I don't trust you in the slightest!
(22-09-2013, 08:11 PM)Ruan Wrote: If you don't need all the boost to burn all the fuel you're supplying, then more boost than required places more strain on the turbo and intercooling system... Also the pumping losses of the engine having to compress even more air in the cylinders is kinda pointless... Turn it down to the sweet spot of no smoke, but not higher than it need be.
Now you have said that how is a td04 @25psi with a welded wastegate and 9mm bosch?
  Lucas K14 Boosting 2 Bar daveylennon93 9 5,808 01-01-2015, 01:42 PM
Last Post: daveylennon93
  top mount td04 not boosting DagDag53 24 11,112 04-12-2014, 09:24 PM
Last Post: daniel.mountain.7
  XUD *over boosting* ? ADV_93 6 4,715 01-08-2014, 08:21 AM
Last Post: Ruan
