Noob setup bosch
Noob setup bosch
Got my Bosch fitted earlier in the week an just sorting the fine tuning but I'm a bit stuck,
Nothing seems to happen until the throttle is about half way. My old bosch u only had to touch the throttle an would rev the arse off
Bit stuck on what to do etc
It will start an idle (a bit rough) but when messing with throttle doesn't seem to respond
Any help
(I know there is guide but I am really thick)
Has the throttle lever been put on the correct spline?
got the throttle arm on the right splines??
Any pics of what should look like,
Sorry for thick questions but I'm piss soaked wet from. Being outside
You wont tell from a pic.
But did you put the throttle arm on yourself?...if so, how?
is it a standard 9mm?
I didn't do the conversion jenks did,
It feels like there is nothing till half way.
Will get video uloaded
is there no resistance at all and no engine change at all with the first movement of the arm?
Nah nothing when first press it the video looks like there is a delay lol
Video uploading now excuse noisey idler lol
at full throttle...is it ACTUALLY full throttle!?
No it don't work 2 mins uploading elsewhere
Try removing the arm and turning the spline clockwise one or two splines in relation to the arm and bolt it back up
just remember to mark it so that you can put it back how it was if needed
^^^ yeah this for sure.
mark arm to the slot in the shaft for future ref
remove arm bolt.
Take arm just above splines.
get screwdriver on to the shaft, turn it clockwise till it stops. drop arm back on splines. bolt back on.
try it!
https://www.youtube.com/watch?v=GTneDagm...ata_player
Private video
Updated sorry bud
mine did this when i turned down the max fuel to much
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Looks like you need WAY more max fuel....
[Image: sigi-2.png]
(15-09-2013, 04:13 PM)darrenjlobb Wrote: Looks like you need WAY more max fuel....
yep funnily enough got a video on my phone of mine doing this exact thing turns out i turned the fuel down to much wind it in a bit and itll be fine
Thanks boys will have a look.
Yeah more max fuel or wind in a minimum throttle travel screw to take up the slack.
Really appreciate it all working now.
Fook me that's fast Lol
Rep when on pc
  Bosch pump and engine setup bashbarnard 4 2,951 07-11-2014, 06:30 AM
Last Post: bashbarnard
  Stoke members bosch setup clarkey2010 7 3,758 20-05-2014, 03:43 PM
Last Post: 205steve
  Bosch setup lda therefused 4 3,043 15-10-2013, 12:33 PM
Last Post: therefused
