03-09-2013, 11:21 PM
Anyone able to help me out? In desperate need of these for both doors
Thanks
Thanks
Wanted: 306 door loom with 21 wires
Thanks
03-09-2013, 11:51 PM
fix it in meantime?
second hand looms could be no better or worse! Wishes for more power...
04-09-2013, 12:50 AM
(This post was last modified: 04-09-2013, 12:51 AM by bigtone0777.)
I'd defo spend a few hours soldering and shrink wrapping your existing ones over fitting second hand ones as the chances are your gonna have the same problem later if not immediately.........either that or but new ones
04-09-2013, 06:21 AM
Its so much easier just to replace the entire loom
04-09-2013, 06:43 AM
(04-09-2013, 06:21 AM)Daniel306 Wrote: Its so much easier just to replace the entire loom it is if you buy a new loom which are hugely expensive and are still wired too short. personally I would say even with a new loom, cutting open the boot and soldering in a small length of wire on a couple of broken ones is simpler than doing the entire loom Wishes for more power...
04-09-2013, 08:30 AM
The plug is too far gone there's not enough wires there to work with "/
I've found a passenger one on eBay but need a drivers "/
04-09-2013, 08:52 AM
what phase is this for??
I got a ph1 drivers loom/plug. been repaired. Wishes for more power...
04-09-2013, 12:54 PM
2 but that shouldn't matter
As long as there's 21 pins in it
04-09-2013, 01:16 PM
(04-09-2013, 06:43 AM)Piggy Wrote:(04-09-2013, 06:21 AM)Daniel306 Wrote: Its so much easier just to replace the entire loom Iv done both ways, changing the lot is quicker and far easier than trying to fit a new plug
09-09-2013, 11:41 AM
Bump have a passenger side just need drivers now
17-09-2013, 05:15 PM
Bump up
| Wanted: Drivers Door Loom | Jama | 4 | 2,727 |
12-07-2014, 04:02 PM Last Post: mspdan |
| Wanted: Door loom | Daniel306 | 8 | 3,876 |
02-11-2013, 10:36 PM Last Post: Daniel306 |
| drivers door wiring loom | Nadine | 11 | 4,864 |
01-07-2013, 12:11 PM Last Post: CJ_Derv |
