Threads: 40
Car Model/Spec: Moonstone Ph3 GTi-6
28-08-2013, 04:49 PM
(This post was last modified: 28-08-2013, 04:52 PM by callumcull.)
My driver side window control switches have just stopped working, the passenger side is all good. Previously it only worked when the door was shut.
Any ideas? It's a ph2 GTi-6
Just started working now. Dafuq?
Now stopped working. Whaaaaa
wiring in door loom.. it should work with door open and shut ...so points to wiring in door loom to me
Threads: 11
Car Model/Spec: Ph3 Meridian HDI
What Piggy said ^^^^^^^^^
I've got the same problem with my central locking on my drivers door, if I wiggle the loom about it works again. Gonna have to either buy a new loom to solder in or replace the individual wires
Threads: 40
29-08-2013, 08:55 AM
(This post was last modified: 29-08-2013, 08:57 AM by callumcull.)
Is the loom easy enough to replace should I need to? I can't see where it goes behind the dash. Or should I just repair the wiring should it happen again?
I took the spring off the clutch pedal last night, Midnightclub did warn that it flies off, but f*ck me it really does. Really didn't expect that last night haha
