banging from rear back wheel when going over bumps
the rear bang from back near side im right in saying the shock has had it, I understand they easy replace. any guidance guys would help.
Moved to the right section. Banging could indicate that the rear beam is broken (bearings have gone) and needs replacing. Is there any camber on the rear wheels?
no camber
(16-08-2013, 09:07 PM)himindoors Wrote: no camber
there is some oil residue on the shock, but its a gas type
are you sure it's not rear beam mounts?
Could be one of the beam mounts as above, i have just changed all of mine and now no more knocks.
not sure don't handle odd but will get my mate to check it over, thanks for the help guys, the parts arnt too expensive I understand
(16-08-2013, 09:15 PM)himindoors Wrote: not sure don't handle odd but will get my mate to check it over, thanks for the help guys, the parts arnt too expensive I understand
Depends, i wouldn't buy cheap ebay ones as they won't last.
rock the car in reverse with handbrake on...if it knocks, likely beam mounts.
(17-08-2013, 10:40 AM)Piggy Wrote: rock the car in reverse with handbrake on...if it knocks, likely beam mounts.
wont help front beam mount are a pig to diagnose unless they are hanging and these are the ones likely to be banging
if the beam aint cambered and shocks are ok...99% of time it be mounts!
anti roll bar! i bet the end plates are lose!
I would say beam mounts
Its either the rear mounts, ARB end plates where the bush has worn out possibly or similar and the last one is the lower shock bolt nut, this has been known to come loose and cause knocking.
there is another possible cause... loose spare wheel, will knock against the boot floor over some bumps, mine's doing it atm, the adjuster is solid so it's soaking in plusgas until tomorrow
Project: Formula Peugeot
(22-08-2013, 06:14 PM)John1.4 Wrote: there is another possible cause... loose spare wheel, will knock against the boot floor over some bumps, mine's doing it atm, the adjuster is solid so it's soaking in plusgas until tomorrow
my thoughts that too I checked the spare is flat so might be that
have a look at the shocker bushes,
they sometimes move off them
well the banging was coming from a tyre cage, with a flat tire in rack. Der what a muppet. :-(
fail. /facedesk
Glad you found the problem, least if you hear any other knocks again then you know what stuff to look out for.
lmao atleast it was an easy fix
  rear wheel arch Quietone 4 4,994 16-04-2019, 11:42 AM
Last Post: welshpug
  Rear Disk Wheel Bearing daveylennon93 21 16,609 06-03-2017, 11:24 AM
Last Post: dt_
  Weird banging noise when braking, advice needed. Spoonaltap 19 9,140 27-01-2017, 05:52 PM
Last Post: Spoonaltap
