180mm clutch
hiya, does anyone know the max torque or bhp figures a valeo 180mm clutch can hold.
thanks in advance
iirc they start to give when they reach about 220bhp and / or 200lbft, it'll all be relative though, they may 'last' past those figures, but not for long, your best bet if you fancy running a little more power is to fit one of the 200mm clutches from a saxo/106, a couple of the people on the AXOC run standard 200mm on their turbo's, albeit the peeps who run 300+bhp use paddle / ceramic clutches
hope this helps,
Project: Formula Peugeot
Approximately 200-220lb/ft static, but wear at that will be very high, and you'll probably find the clutch overheats and slips on full bore gearchanges and launches. 160-170lbft is more reasonable if you want it to last.
mine slips at 190lb/ft under full throttle acceleration when it's hot. holds ok otherwise
cheers for the replys guys, ill probs have to upgrade to a 200mm clutch then
