180mm clutch - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: 180mm clutch (/showthread.php?tid=16453) |
180mm clutch - 306Dan - 13-08-2013 hiya, does anyone know the max torque or bhp figures a valeo 180mm clutch can hold. thanks in advance RE: 180mm clutch - John1.4 - 14-08-2013 iirc they start to give when they reach about 220bhp and / or 200lbft, it'll all be relative though, they may 'last' past those figures, but not for long, your best bet if you fancy running a little more power is to fit one of the 200mm clutches from a saxo/106, a couple of the people on the AXOC run standard 200mm on their turbo's, albeit the peeps who run 300+bhp use paddle / ceramic clutches hope this helps, RE: 180mm clutch - Rippthrough - 14-08-2013 Approximately 200-220lb/ft static, but wear at that will be very high, and you'll probably find the clutch overheats and slips on full bore gearchanges and launches. 160-170lbft is more reasonable if you want it to last. RE: 180mm clutch - samass - 14-08-2013 mine slips at 190lb/ft under full throttle acceleration when it's hot. holds ok otherwise RE: 180mm clutch - 306Dan - 14-08-2013 cheers for the replys guys, ill probs have to upgrade to a 200mm clutch then |
